Old Wed, Mar-14-2018, 01:28:09 AM   #1
BacDoc
Reputation: 0 BacDoc is on a distinguished road
Default Flasher Relay?
Right turn signals work but flash fast. All the headlights work too. Drivers side parking light on and high beam only...nothing with turn signal on. Checked bulbs no change. Hazard button gets me nothing. Flasher relay?
Sent from my SAMSUNG-SM-G930A using Tapatalk
Jump to top BacDoc is offline   Reply With Quote
Old Wed, Mar-14-2018, 04:10:15 AM   #2
epj2.9
Reputation: 0 epj2.9 is on a distinguished road
Default Re: Flasher Relay?
I don't get the connection to headlights and parking lights. Fast turn signal is usually a burnt out bulb. The parking light has a second filament for turn signal, so might be burnt out. Check the sidemarker (on the door/fender).
'16 4Runner TEP
'97 M3/4/5
'13 Mini Cooper S
Jump to top epj2.9 is offline   Reply With Quote
Old Wed, Mar-14-2018, 08:55:41 AM   #3
BacDoc
I changed the pass turn bulbs and the side marker is working there too. I get nothing on drivers side, no sounds no lights on cluster. As for the headlight I'm not sure what it is, maybe a ground? But I've put in new bulbs and nothing.
Old Wed, Mar-14-2018, 04:10:04 PM   #4
Earthwormjlm
Imolarot M3
Use a multi-meter and see if you're getting voltage for the turn indicator when on. If not, check right at the wire. If not, trace back till you find voltage.
You changed bulbs, but that doesn't mean you still don't have a contact issue, wiring failure, or relay failure.
Old Wed, Mar-14-2018, 06:58:44 PM   #5
BacDoc
In the column?
I ordered a relay be here in a couple days
Old Thu, Mar-15-2018, 09:40:27 PM   #6
Earthwormjlm
Imolarot M3
In the column?
No, start at the light, then work your way back. That's the basic fundamental of electrical trouble shooting, start at where the expected output is supposed to be, then work your way backwards until you find the fault. That's how I found an invisible cracked trace on my E30's cluster. Turn indicator was working, but the cluster wouldn't light up. Traced signal from the cluster connector to the cluster bulb, checked for continuity, found none, then worked my way backwards, till I found continuity.
Old Thu, Mar-15-2018, 09:43:13 PM   #7
BacDoc
Just realized I'm missing the entire reverse socket on the pass side. Would that disrupt the circuit?
Old Sat, Mar-17-2018, 02:48:11 AM   #8
BacDoc
New relay. I now have driver side signals but pass side flashes fast and no read signal even with new bulb.
Old Mon, Mar-19-2018, 02:49:05 PM   #9
BacDoc
Rear pass bulb holder...I had to mess with the connections and it cleared up my problem. Still have no drivers low beam.
Discussing Flasher Relay? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
