Old Fri, Jul-28-2017, 06:12:31 PM   #1
speeeding
Reputation: 0 speeeding is on a distinguished road
Default Best Value vs. Performance Radiator for Track Duty 2017?
Lately, my coolant temps have been running on the hot side at the track, and I've narrowed it down to the radiator. I see there are quite a few options for radiators, and would like to hear your thoughts on what is the best value. I don't want to pay $1000 when a $300 radiator will work just fine. The car is NA, and I have no plans to go FI in the near future.
A complaint about stock units is the plastic necks. Although most aftermarket radiators have aluminum necks, they still need hoses that have to be fitted with the plastic OE fitting. So you won't be able to avoid using plastic entirely.
Here's what I found so far:
1. Modine ~$260 - OES. Exactly the same as BMW?
2. Nissens OE ~$260 - OE replacement, similar in price to BMW. Not sure about the quality.
3. Genuine BMW ~$296($240 @ Husker) - Some people have been doing just fine with stock.
4. Koyo Koyorad aluminum radiator ~$395-420 - Read good things about this so far.
5. CSF aluminum radiator ~$550 - Not so good reviews on this one.
6. Mishimoto ~$595 - Some documented issues on earlier versions
7. Fluidyne/Turner ~ $695 - Great reviews, but the price is getting up there.
8. Bimmerworld/C&R ~$800 - Similar to Fluidyne?
9. Zionsville ~$1015 - Seems to be the best of the best, but it's also the most expensive
Are there any others out there worth mentioning?
Jump to top speeeding is offline   Reply With Quote
Old Fri, Jul-28-2017, 06:31:09 PM   #2
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
Default Re: Best Value vs. Performance Radiator for Track Duty 2017?
I was just looking at the Koyorad radiator. Read several good reviews on this one with no negative ones so far.
Old Fri, Jul-28-2017, 06:39:30 PM   #3
Brian N
wubalubadubdub
Brian N's Avatar
I would say a fresh OE BMW is probably the best value for money. I know Kaiv used to track with his all the time and swore that new OE is the way to go and he never had any problems.
-My Journal-
Old Fri, Jul-28-2017, 06:54:12 PM   #4
I'd be careful not to assume that having an OE radiator is the problem when the problem is probably having an old, gunked up OE radiator instead.
I couldn't tell from your post if that's what you thought or if you were aware that your OE radiator being a problem is because of it's condition rather being inadequate by design for tracking.
_
Old Fri, Jul-28-2017, 06:58:22 PM   #5
I'd go OE or Zionsville, and nothing in between.
Old Fri, Jul-28-2017, 07:13:46 PM   #6
ctres
ctres's Avatar
Reputation: 0 ctres is on a distinguished road
OE is only $240 from husker. Just got one myself.
Jump to top ctres is offline   Reply With Quote
Old Fri, Jul-28-2017, 07:43:56 PM   #7
HassanEido
HassanEido's Avatar
Lebanon
I went with nissens, no issues at all, but if I had to do it again, I'd buy genuine bmw
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
368.4 whp 289.1 wtq
Old Fri, Jul-28-2017, 07:55:53 PM   #8
OES is Modine incase anyone is looking to save $. The logo is a big "M"
_
Old Fri, Jul-28-2017, 07:56:16 PM   #9
cosmos///m3
MMMmmmmmm....
cosmos///m3's Avatar
Reputation: 0 cosmos///m3 is on a distinguished road
Why? Personal opinion or actual data to back up your reasoning?
2005 ZCP Schwarz II/Imolarot 6spd ///M3 ||| 1999 Estoril Blau/Estoril Blau ///M Coupe "Clownshoe"
2014 Alpinweiss Uni/Mokka X5 ///M Package (wifey)
Originally Posted by hum3a
man i need a fu<kin wife to run errands for me......fu<k grocery shopping
Jump to top cosmos///m3 is offline   Reply With Quote
Old Fri, Jul-28-2017, 08:05:12 PM   #10
Dave B
M3 collector
Dave B's Avatar
Italy
Too many documented issues with C&R, Fluidyne, Mishi, too little known about the others... and at those 600+ price points it makes sense to just pay all the way up to Zionsville anyway.
Discussing Best Value vs. Performance Radiator for Track Duty 2017? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
