Old Sat, Jun-30-2018, 07:42:22 PM   #1
aasturi2
Reputation: 0 aasturi2 is on a distinguished road
Default Passenger side lower
Hello was wondering if anyone can help me out. I installed new Koni yellows with H&R springs and the car is lower on the passenger side by about 0.5-1 inch. The whole install process went smooth and i canít figure out why it is lower on the passenger side than the drivers side. I looked it up and people were saying that it was normal and that BMW did that to compensate for the weight of the driver but i was a little skeptical about it thank you in advance !
Jump to top aasturi2 is offline   Reply With Quote
Old Sat, Jun-30-2018, 07:44:21 PM   #2
ThunderMoose
Default Re: Passenger side lower
Have your driven it around a bit before checking your measurements? If not, suspension can bind slightly.
#67 2017 NASA TX TT3 Champion
Old Sat, Jun-30-2018, 07:53:12 PM   #3
aasturi2
Thank you yes i drove it around for a day and noticed it when it was parked the next day.
Old Sat, Jun-30-2018, 10:25:18 PM   #4
neopolymath
neopolymath's Avatar
Reputation: 0 neopolymath is on a distinguished road
On older BMWs, the driver's side is always slightly higher when no one is in the vehicle to account for the driver's weight. No clue if newer cars are the same though.
Jump to top neopolymath is offline   Reply With Quote
h&r, koni, passenger side, ride height, suspension
Discussing Passenger side lower in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
