Old Fri, Oct-04-2013, 06:39:49 PM   #1
TO///M3
///M Life
TO///M3's Avatar
Reputation: 0 TO///M3 is on a distinguished road
Question Putting Springs on Stock Shocks
Hello,
My name is Thomas and maybe some of you have seen my other posts but i just bought a 2010 E92 M3. Ive been doing ALOT of research in this section of the forum to get a basic idea of what the "general" mods people do to these M's.
As i was looking for suspension, i feel like alot of people get springs and not full coilovers. So far, i like the ride of the stock suspension and this car is my DD and will probably never see track time, so i dont really need coilovers. But i do want to get a more aggressive stance without spending almost 2k on coilovers when i really just want the aesthetics...
Is there any issue putting lowering springs on stock stocks? I know its usually frowned upon and can damage the stocks... is it a different story for the E92 suspension? I have EDC by the way... Im looking at the RD Sport Springs http://www.pyspeed.com/RD-Sport-Spor...sport-8101.htm
Thanks in advance
2010 LeMans Blue Metallic E92 ///M3 DCT
Macht Schnell Test Pipes | AE Performance Exhaust | KW S/O Kit | Lux V4
Daily Driven like it should be.
Jump to top TO///M3 is offline   Reply With Quote
Old Fri, Oct-04-2013, 07:11:16 PM   #2
C-M2
Reputation: 0 C-M2 is on a distinguished road
Default Re: Putting Springs on Stock Shocks
Nothing wrong with putting springs on a car. It will decrease the life of the struts and the ride will be different. A lot of people run the RD's.
I currently run a KW sleeve over kit. In the spring I will be moving to the Ohlins R/T Coilovers.
2009 Space Gray e92 M3 Coupe/// OEM C/F Performance Trim, OEM Performance Steering Wheel, OEM Performance C/F Limited Center Console, OEM C/F Performance Mirror Covers, OE GTS Front Splitter/Lip, LCI Tails, IND Blacked Out Trim Pieces, SuperSprint Race Section 1-2-3, Apex EC7s 18x10/18x11, Stoptech 6pot, AlekShop 90mm Studs, AlekShop Half Cage, Recaro Profi XL's, Planted Seat Hardware, Custom Rear Seat Delete, Ohlins R&T Coilovers, Vorshlag Camber Plates, RD Sport Sways, AlekShop Solid/Delrin Rear Subframe Bushings, AlekShop Solid/Delrin Diff Bushings, Dinan Intake
Sold
04 ///M3 Jet Black Coupe
Jump to top C-M2 is offline   Reply With Quote
Old Fri, Oct-04-2013, 10:19:11 PM   #3
tony093
Reputation: 0 tony093 is on a distinguished road
H&R on EDC shocks here for about 2 years with no issue.
Jump to top tony093 is offline   Reply With Quote
Old Sat, Oct-05-2013, 12:26:10 AM   #4
endlessNA2
DHS
endlessNA2's Avatar
Reputation: 0 endlessNA2 is on a distinguished road
Don't waste your time with lowering springs. I have done this with 3 M cars and wish I would have never done it.
The problem is ALL springs leave the front with almost an inch of gap. To me that is unacceptable and looks bad. The Z4MC was really bad for this.
So do it right the first time and get coilovers. If you are on a budget then save some money and leave it stock until you get coilovers. You will be glad you did.
Good luck.
Jump to top endlessNA2 is offline   Reply With Quote
Old Mon, Oct-07-2013, 04:24:18 AM   #5
admranger
Registered troublemaker
I like the Eibach pro kit springs I put on the E46. Slight drop (which may not do what you like) and progressive rate springs so your daily driver ride isn't atrocious. Not sure they make them for the E9x chassis though.
Sadly sold: 11 E90 M3, Melbourne/Black/Fox Red/Black, 6MT, roof, PP2, heated seats, Eibach Pro Kit, GC Street camber plates, Arc-8's, Technic harness, JL XD 600/6
19 X3M40i, Carbon/Oyster
18 330i xdrive GT, Mineral White/Black
Old Mon, Oct-07-2013, 01:05:50 PM   #6
TO///M3
///M Life
TO///M3's Avatar
Good luck.
It looks like the RD springs give a pretty aggressive drop and i really dont need the benefits coilovers give...
Im not going to track the car, and i dont really car about adjusting this and that, so the price difference in springs vs coils arent justified for me.
I really just want to make sure putting springs only wont mess up anything on my car, like blow my shocks out or ruin the EDC function.
Old Mon, Oct-07-2013, 09:01:13 PM   #7
lcrain
lcrain's Avatar
Reputation: 0 lcrain is on a distinguished road
Sounds like you have made up your mind. Adding springs won't mess up anything per-se, but they will likely lead to shocks losing a little bit of their life. The springs will make the ride slightly worse, and the function of the EDC will likely be affected though not such that it will completely defeat the functionality of the shocks. From what I understand, the changes from each setting to the next is less noticeable.
Coilovers are overkill for some people, but the advantage they offer is a set of dampers/springs that are designed to work together, like the OEM suspension. Many who install just lowering springs also install e36 bumpstops to restore some of the suspension travel lost when adding lowering springs.
Jump to top lcrain is offline   Reply With Quote
Old Wed, Oct-09-2013, 06:32:00 AM   #8
Curt2000
Reputation: 0 Curt2000 is on a distinguished road
Eibach springs with spacers looks very clean IMO...here is a pic of my car with Eibach Pro-kit and 15mm front / 12mm rear spacers...no rubbing issues at all!
Jump to top Curt2000 is offline   Reply With Quote
Old Wed, Oct-09-2013, 02:23:45 PM   #9
TO///M3
///M Life
TO///M3's Avatar
looks awesome man, i want a little more aggressive drop than the Eibach though, you think i would rub if i did 18mm front / 15mm rear with stock 19s?
Old Wed, Oct-09-2013, 08:25:28 PM   #10
Curt2000
I've never had any problems so I'm sure a couple extra mm's wont be too bad...maybe a slight rub when hitting a bump while turning
lowering springs, springs, suspension
Discussing Putting Springs on Stock Shocks in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
