Old Sat, Jul-20-2013, 10:26:31 PM   #201
bradnic
bradnic's Avatar
Reputation: 0 bradnic is on a distinguished road
Default Re: M3 - NFL running back style: TC Kline suspension, RTAB and OEM brake upgrade
thank gawd for archive.org. no idea what's going on with deleting DIY info. whatever the feud is the community suffers for it.
UPDATE: didn't realize the DIY came from The McLaren Guy.. wow. Anyway info's still available at the link.
http://web.archive.org/web/200710250...d.php?t=179844
Also anyone considering TCK D/As, do not hesitate to contact TC Kline. TC is very personable and helped me through a bunch of stuff.
Jump to top bradnic is offline   Reply With Quote
Old Sat, Jul-20-2013, 10:27:49 PM   #202
Karbon
Back to Basics
Karbon's Avatar
Reputation: 0 Karbon is on a distinguished road
Originally Posted by bradnic View Post
since the pics appear to be missing, can anyone shoot a pic of their camber plates installed? from the top is fine, great if you can shoot a pic from underneath too.
MANY thanks.
What do you need to know; the orientation or how to stack the camber plates with the washers?
Jump to top Karbon is offline   Reply With Quote
Old Sat, Jul-20-2013, 10:37:14 PM   #203
bradnic
bradnic's Avatar
orientation most importantly. If you're new to this stuff there's no install doc. This DIY was the only thing I've found online and it had deleted info : this was the key pic I was looking for - if you read the thread it's no longer here.
believe it or not, I couldn't find a pic like that anywhere.
What washers are you referring to btw?
As to why I'm wondering about this, just bought my M3 earlier this year and was fortunate enough to have a full TCK D/A setup with it. It was a bit weird though as it had E36 plates installed! My guess is TC didn't have E46 plates early on and the original purchaser figured out how to use E36 plates. It didn't seem to look right though as the camber and caster adjustment angles didn't appear to be in the right place. So bottom line it was a hacked install.
As to ride, I second alot of the comments here. the setup is quite driveable for DD use (I have 550/600 last I checked). TC is also a terrific guy, very hands on and extremely helpful over the phone. I rebuilt the camber plates with new parts but have just now but Obioban's set of E46 plates, so I should be 'legit' soon enough..
Thanks for your reply
Old Sun, Jul-21-2013, 04:23:07 AM   #204
Karbon
Back to Basics
Karbon's Avatar
That looks like the correct orientation in the picture. As long as the camber plates adjust along the direction of the camber movement on the plates, then you have them in the right direction.
The washers I was referring to were the ones that placed in between the bushings and the camber plate on the rod of the strut. Don't worry about it as it looks like your plates are already installed on your struts.
Looks like another member posted the DIY with the pictures in the post above .
back, brake, kline, nfl, oem, rtab, running, style, suspension, upgrade
TC Kline Suspension from E46 M3 whayes Parts for Sale/Wanted 30 Fri, Jun-27-2008 06:30:41 PM
Garage Cleaning Cont...FS: UUC SS Brake Lines / RTAB & FCAB Tools / OEM LED Left Tail BAV_M_PWR Parts for Sale/Wanted 16 Wed, May-28-2008 01:49:36 PM
TC Kline Full D/A Suspension Peterp Parts for Sale/Wanted 22 Thu, May-22-2008 10:43:13 PM
Issues running 4 oem 18" rear wheels on stock suspension? liuk3 M3 Track: Racing and DE 20 Sat, Apr-21-2007 06:32:27 AM
E46 M3 OEM Brake Upgrade BlueSky Parts for Sale/Wanted 15 Fri, Mar-02-2007 01:09:27 AM
Discussing M3 - NFL running back style: TC Kline suspension, RTAB and OEM brake upgrade in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
