Old Wed, Jun-01-2016, 05:44:49 PM   #11
Mike_M
Mike_M's Avatar
Reputation: 0 Mike_M is on a distinguished road
Default Re: Not the RTAB's?
Noticed a crack in the spot where the RTAB goes into. Any relevance?
Jump to top Mike_M is offline   Reply With Quote
Old Wed, Jun-01-2016, 07:12:03 PM   #12
KubinB
BMMMR
KubinB's Avatar
Reputation: 0 KubinB is on a distinguished road
is that a crack or where someone cut out the original metal ring RTAB
///M3 2002 TiAg / Imola 6MT
The Transformation
Jump to top KubinB is offline   Reply With Quote
Old Wed, Jun-01-2016, 08:15:56 PM   #13
Mike_M
Mike_M's Avatar
That's a very good question. Seems more probable that it would be that.
Side note: the powerflex bushings I put in seemed to be very tight against the bracket that goes over it that attached to the car.
Is this normal or should it be able to move more freely?
Old Wed, Jun-01-2016, 08:19:03 PM   #14
KubinB
BMMMR
KubinB's Avatar
no with the torque its not supposed to move. make sure you preload it
The Transformation
Old Wed, Jun-01-2016, 08:59:34 PM   #15
Mike_M
Mike_M's Avatar
I went with Poly so I thought I didn't have to
Old Wed, Jun-01-2016, 09:01:35 PM   #16
Mike_M
Mike_M's Avatar
Update: Just went for a highway drive and the car feels much better than before. Definitely don't get as much wandering. Almost feels like any that I have is now from the front so I'm guessing FCAB's next.
Just goes to show you that even though a part looks perfectly fine, doesn't mean it is.
Old Fri, Jun-03-2016, 03:24:23 AM   #17
04yfz
Reputation: 0 04yfz is on a distinguished road
How many miles on your shocks? Worn rear shocks can also cause that floating feeling.
Pat
Jump to top 04yfz is offline   Reply With Quote
Old Fri, Jun-03-2016, 10:36:00 PM   #18
Mike_M
Mike_M's Avatar
One of the PO's put the suspension on probably 60k miles or so ago. They're koni yellows with ground control springs.
I just checked the RSM's and the tops seem to be oily. I don't know if this has any relation or not.
I might be picking up some KW V2 suspension from a friend.
bushing, rtab, suspension
Discussing Not the RTAB's? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
