Old Tue, Nov-15-2011, 08:40:50 AM   #101
0-60Motorsports
Established 1998....
0-60Motorsports's Avatar
Bahrain
Default Re: Drivetrain maintenance & suspension upgrade time
Originally Posted by gnoy26 View Post
otw = on the way
subframe good? err yes i think hahaha... at least by observation =P
probably will raise the car and run it and shift a gear see what jolts...
*stresssssssss
You need to drop the subframe to check properly. All the parts that you have on the way, make sure you inspect them before u replace them. Also if you have aftermarket RTABs check if all surfaces and the holder are lubricated with Copper grease. Its all a matter of checking.
Jump to top 0-60Motorsports is offline   Reply With Quote
Old Tue, Nov-15-2011, 09:26:25 AM   #102
gnoy26
gnoy26's Avatar
Reputation: 0 gnoy26 is on a distinguished road
Malaysia
thanks for the advice... ill probably take it from there.
02 Estoril Blue M3 Coupe JDM Spec SMG M-texture Alcantara
SIC Z221 2.32.8 171013
SIC A050 2.35.3 060313
gnoy26 Journal
Jump to top gnoy26 is offline   Reply With Quote
Old Tue, Nov-15-2011, 10:45:19 AM   #103
0-60Motorsports
Bahrain
Cool. Anything else Post up or PM me any time. Good Luck
Old Tue, Nov-15-2011, 08:53:02 PM   #104
Jackbenimble
scantilyclad
Reputation: 0 Jackbenimble is on a distinguished road
Interested as to how the yellow Powerflex bushings are holding up?
I was advised not to install them because they are "softer then oem" and rip. after some years passed I found a couple threads on bimmerfourms and e46Fanatics that confirmed what I was told
hopefully they have since addressed the issue although here is a recent thread with a bunch of complaints.. albeit e46fanatics but its still good info
http://forum.e46fanatics.com/showthread.php?t=840635
Jump to top Jackbenimble is offline   Reply With Quote
Old Tue, Nov-15-2011, 11:21:45 PM   #105
0-60Motorsports
Bahrain
Your right, I kept OEM.
Old Sun, May-05-2013, 08:50:19 PM   #106
Mpowerza
Reputation: 0 Mpowerza is on a distinguished road
South Africa
1) great work! All good things to do . You best be keeping the car for a long time after all of this.
2) OMFG, I can believe how much dirt/dust there is on EVERYTHING! It's blowing my mind!
3) I need to do the diff cover/bushings soon. I'm thinking ~150k....
HI Guys,, Do you know if the diff cover and bushings are automatically replaced when BMW replaces a faulty Diff? I had my entire DIFF replaced by BMW under warranty about 40 000 miles ago. I know you cant buy the bushes alone, you have to replace the whole cover. Since Im doing some work on the rear end, should I just replace the cover again with the bushings? Its about $160.
Thanks !
2001 Steel Grey, 6M/T, S/R ERB, HK Audio , AC Schnizer Exhaust, 19" BBS LM Reps, Tein SP
Jump to top Mpowerza is offline   Reply With Quote
drivetrain, maintenance, suspension, time, upgrade
Discussing Drivetrain maintenance & suspension upgrade time in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
