Old Mon, Dec-04-2017, 05:11:31 PM   #1
Drewster
Drewster's Avatar
Default FYI - looks like a good fix for broken VANOS harness
https://www.bmotorsports.com/shop/ad...m_medium=email
Old Mon, Dec-04-2017, 06:01:42 PM   #2
qualicas
qualicas's Avatar
Default Re: FYI - looks like a good fix for broken VANOS harness
Thanks, this might come in handy right away. I noticed my connector is sort of screwed up when I pulled out the coil pack. Probably the accident the car was in could have had something to do with it!
Old Mon, Dec-04-2017, 06:20:10 PM   #3
bigjae1976
Those connectors get stuck on because of oil and grease. Itís a beotch getting it off without some pliers.
I just zip tie the wire to the connector on the solenoid. Provides strain relief and makes having a connector less necessary.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Mon, Dec-04-2017, 06:43:28 PM   #4
Looks like the OE BMW one is less than half the price...?
https://www.ecstuning.com/b-genuine-...138383300~oem/
Old Wed, Dec-06-2017, 05:35:23 AM   #5
mrgizmo04
mrgizmo04's Avatar
I constantly break these. Good find!
'85 528e 164k miles (sold)
'05 M3 6MT coupe
All DIY: 330 ZHP steering rack, diffsonline 4.1 diff with rem polish, E60 short shifter lever, AKG black diff bushings/subframe bushings, Rogue rtab, Rogue RSM with reinforcement, WPC rod bearings, Beyer driveshaft, Magnaflow catback, new SAC/flywheel, rear main, VANOS bullet proofing with anti-rattle, valve adjustment, cooling refresh.
Old Wed, Dec-06-2017, 05:53:52 AM   #6
My thoughts exactly ... ?
Old Wed, Dec-06-2017, 02:22:39 PM   #7
Drewster
Drewster's Avatar
And then you pay almost $20 for pins and seals if you go that route
https://www.ecstuning.com/b-genuine-...h/61130005199/
Granted, you could buy the OE connector and use pins and seals from Ballenger .. but that's part of knowing there's another option out there
Old Wed, Dec-06-2017, 02:27:59 PM   #8
I assumed you were just concerned about the connector itself (since it's normally the side clips that fail), and would transfer the pins from the original. Replacing them all is more invasive that's I'd choose to be if not necessary!
Old Wed, Dec-06-2017, 03:38:54 PM   #9
Drewster
Drewster's Avatar
Pins fail and corrode over time - If my connector ever failed, I would just crimp on new pins and seals rather than de-pinning and re-using the 15 year old originals.. but that's just me :shrug:
To each their own - I was just letting folks know there's another source for them.
Old Wed, Dec-06-2017, 03:42:06 PM   #10
Drewster
Drewster's Avatar
Personal tip - use a screwdriver to twist and put force against the front face of the connector and what it's connected to while you push the latch down. More of the force goes in the axis it needs to so you're a *little* less likely to break the housing.
Discussing FYI - looks like a good fix for broken VANOS harness in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
