Old Mon, Dec-04-2017, 03:12:10 PM   #61
Default Re: Help me get into the 3000 lbs club!
Originally Posted by AW///M3 View Post
Which sunroof delete panel is everyone using?
http://www.bimmerworld.com/Carbon-Fi...l-Panel_4.html
Old Mon, Dec-04-2017, 03:13:42 PM   #62
The big one
Current Cars: 2005 IR/IR M3, 2001 LMB/blk M5, 03 530i, 04 M3 wagon
Old Mon, Dec-04-2017, 04:29:09 PM   #63
Originally Posted by CrookedCommie View Post
Vox how long did it take you to remove the full harness and can you share what the cost is to trim it down? I know there was a guy on the SpecE46 FB group offering something similar (you ship him harness and he'll trim it and ship back).
The radio harness is separate from the main harness.
You have to remove the entire interior, heater core, head lights and bumper. Once you do that...4 hours max?
Old Mon, Dec-04-2017, 04:34:42 PM   #64
I didn't know that! That's excellent news for the effort required for my project!
And chance you weighted the stereo harness?
Old Mon, Dec-04-2017, 04:38:39 PM   #65
Found it.
http://www.realoem.com/bmw/enUS/part...&q=61116956035
Looks like the stereo harness is 8.4 lbs. Excellent
Old Mon, Dec-04-2017, 04:59:01 PM   #66
Found it.
Screwing with the radio harness alone is definitely easier. The most annoying thing is trying to get the front carpet out without permanently screwing it up (if you're trying to be precise about it)... otherwise two cuts with a box cutter and she's out.
Be mindful not to remove your antenna module harness on accident, or you might discover keyless entry no longer works
Old Mon, Dec-04-2017, 05:04:35 PM   #67
Can't think of any chassis features I'm not retaining, so seems like the stereo harness is all I should be removing for my project (I'm assuming the stereo harness includes the CD changes/bluetooth/nav/etc wiring-- though now realize that might not be true...)
Old Mon, Dec-04-2017, 05:18:06 PM   #68
CrookedCommie
Captain Slow
CrookedCommie's Avatar
Reputation: 0 CrookedCommie is on a distinguished road
Bulgaria
Same, I didn't know that. In that case I might pop off the dash again and remove just the stereo harness for now.
Jump to top CrookedCommie is offline   Reply With Quote
Old Mon, Dec-04-2017, 05:24:39 PM   #69
IIRC, the only place it connects into the main harness behind the HVAC controls. Itís a plug that just disconnects.
The front speaker wires run down the trans hump, under carpet right towards the door on both sides. You might need to pull up the carpet in the foot wells. Donít think you need to remove the front section.
Old Mon, Dec-04-2017, 05:25:29 PM   #70
Vox Populi
Vox Populi's Avatar
Reputation: 0 Vox Populi is on a distinguished road
i had my shop remove it when they pulled the motor. I was billed for 2.5hrs (dunno how long it actually took though..I give them alot of work :-)
I am absolutely going to do a write up of the service when it's done. I'm using the guy you reference (Kevin tulay).
Build Thread
Jump to top Vox Populi is offline   Reply With Quote
Discussing Help me get into the 3000 lbs club! in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
