Old Fri, Apr-19-2019, 06:32:39 PM   #1
ChristianMCG
Reputation: 0 ChristianMCG is on a distinguished road
Spain
Default Weds Maverick 709M
Hello,
I'm planning mount these wheels into my car and trying to clarify the specs. I own E46 M3 and not sure how to get big lip with these wheels without make modifications on the fendders. Any help would be appreciate.
For start I was thinking in:
- 19x10,5 ET35 -> Front
- 19x10,5 ET25 -> Rear
Do you think this could it fit good?
Thanks in advance,
Regards,
Jump to top ChristianMCG is offline   Reply With Quote
Old Fri, Apr-19-2019, 06:35:03 PM   #2
jeremywd40
jeremywd40's Avatar
Reputation: 0 jeremywd40 is on a distinguished road
Default Re: Weds Maverick 709M
They’ll fit. You’ll want spacers.
2003.5 Silver Grey / Red - SOLD
2003.5 Silver Grey / Black - SOLD
2002 Estoril Blue / Black - Daily Driver
Jump to top jeremywd40 is online now   Reply With Quote
Old Fri, Apr-19-2019, 06:42:57 PM   #3
ChristianMCG
Spain
Thanks Jeremy,
Do you think will rubbing in the fendders?, and how big is the lip?
Old Sat, Apr-20-2019, 12:10:25 AM   #4
jeremywd40
jeremywd40's Avatar
The lip shouldn't be an factor. Width and back spacing (offset) should be your guides. Do some searching and look at photos of other wheel setups on this forum. You'll get an idea of what its going to look like.
And forget what I said about spacers. At that width, you might be flush front and rear requiring some camber (front) and rolling (rear) if lowered. Fronts are going to be tight.
Old Sat, Apr-20-2019, 02:41:35 AM   #5
Nambo
Reputation: 0 Nambo is on a distinguished road
Would look pretty sweet!
Jump to top Nambo is offline   Reply With Quote
Old Sat, Apr-20-2019, 08:31:52 AM   #6
ChristianMCG
Spain
Thanks mate. One important thing that I forgot to comment is that I have BBK AP-Racing F+R. So I suposse will need spacer 100% for clearance?
In that case if I choose those specs:
19x9,5 ET25 with tires 255/35/19 (with spacer 10mm effectively ET35)
19x10 ET25 with tires 275/35/19 (with spacer 10mm effectively ET35)
Both Et's seems fit good:
https://www.wheel-size.com/calc/?whe...cl=35mm&sr=0mm
Do you think could it fit good?
Thanks in advance,
Regards,
Cristian.
Old Tue, Apr-23-2019, 01:39:44 PM   #7
ChristianMCG
Spain
Hi, noone can confirm?
Discussing Weds Maverick 709M in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
