Old Mon, Jan-23-2017, 05:35:07 PM   #21
fattycharged
can't even
fattycharged's Avatar
Zimbabwe
Default Re: Does Your E46 BMW Consume Oil?
have never noticed a drop and I daily the M often
Topo Chico
Old Mon, Jan-23-2017, 05:37:14 PM   #22
Tp///M3
Got ///M?
Tp///M3's Avatar
Reputation: 0 Tp///M3 will become famous soon enough
Laos
Check my oil level on regular basis, never had to add. Daily drive also.
04 CarbonBlack/ImolaRed
Jump to top Tp///M3 is offline   Reply With Quote
Old Mon, Jan-23-2017, 05:53:07 PM   #23
TEASE///M3
TEASE///M3's Avatar
Reputation: 0 TEASE///M3 is on a distinguished road
1 out of 4 S54 I've owned has consumed oil. Needless to say I hated that.
Untitled by . McFarlin, on Flickr
2006 M3 ZCP Interlagos Blue Manual Cinnamon 6MT Slicktop
RIP 2002 M3 Tiag Dove Grey 6MT
Jump to top TEASE///M3 is offline   Reply With Quote
Old Mon, Jan-23-2017, 07:15:24 PM   #24
angelr
angelr's Avatar
Reputation: 0 angelr is on a distinguished road
I've owned two and neither burned any oil into the 120-130k range and counting using tws.
07 z4 m coupe aw over ir
04 IR smg coupe- Dead
Jump to top angelr is offline   Reply With Quote
Old Mon, Jan-23-2017, 08:59:00 PM   #25
sergbaja5t
Uncle Grandpa
sergbaja5t's Avatar
Reputation: 0 sergbaja5t is on a distinguished road
Neither of mines consume, but I am not looking to hard either.
2016 Ford F150 Screw sport Egoboost
2005 SilberGrau Met/Schwarz M3 Smg, VMR 703 reps, Megan Racing sec 3, Bilstein PSS10/Koni
2002 StahlGrau MET/Schwarz M3 6spd AA headers, Supersprint x-pipe, AA Gen 4 sec3, Besian hub and seals, Turbotoy hardware, Rouge Engineering Vanos & Coolant pipe, Arp studded, H&R/ST/Bilstein coilovers, M220 19's. S54 timing tool w/ two guide pins**FOR RENT** Atlanta valve adjustment service(ask about rates)! Simple coding & DME scanning (Atlanta area)
Jump to top sergbaja5t is offline   Reply With Quote
Old Mon, Jan-23-2017, 09:10:10 PM   #26
icecream
Registered Apples
icecream's Avatar
Originally Posted by bimmerfan08 View Post
You all cannot say with certainty that your S54s are not consuming at least a drop. Just because you aren't adding any oil does not mean your engines aren't consuming even a minuscule amount that in turn would be barely, if at all noticeable. Just playing the semantics card.
Not a drop. Seriously with certainty.
Old Tue, Jan-24-2017, 03:46:37 AM   #27
SeanE46
SeanE46's Avatar
Reputation: 0 SeanE46 is on a distinguished road
Armenia
Mine drinks like 1 quart every 500 miles
2001 M3 6MT TiAg Coupe SOLD
2002 M3 6MT TiAg Coupe SOLD
2004 M3 SMG Silver Grey CURRENT
Jump to top SeanE46 is offline   Reply With Quote
Old Tue, Jan-24-2017, 04:59:17 AM   #28
m3nt0s
Reputation: 0 m3nt0s is on a distinguished road
Roughly 4k miles per year with annual spring oil change, over 83k miles on the car now. I check oil at least several times per year via dipstick and proper procedure. After the CPV o-ring was done, haven't lost a visible drop.
Jump to top m3nt0s is offline   Reply With Quote
Old Tue, Jan-24-2017, 10:19:16 AM   #29
Halftim3
Reputation: 0 Halftim3 is on a distinguished road
With mine above 150k miles, I'm happy mine doesn't consume oil.
After 5k miles of an oil change, the oil level is exactly where I saw it 5k miles ago.
I have the upgraded cpv o-ring and I drive it daily.
Jump to top Halftim3 is offline   Reply With Quote
Old Tue, Jan-24-2017, 04:50:37 PM   #30
E46_USMC
E46_USMC's Avatar
Reputation: 0 E46_USMC is on a distinguished road
Mine used to consume a liter every 1000 miles.. turbo was installed, and two oil changes later and has not burned off any.. who knows
Jump to top E46_USMC is offline   Reply With Quote
Discussing Does Your E46 BMW Consume Oil? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
