Old Thu, Jul-14-2016, 05:02:40 PM   #11
CrookedCommie
Captain Slow
CrookedCommie's Avatar
Bulgaria
Default Re: CrookedCommie's Track/Street Build
Originally Posted by Tom_schleg View Post
This build thread is awesome, Ive been following it on insta. Very jealous of your subframe reinforcement
Originally Posted by M clunk View Post
I like what I see!
I'll be following this build. Keep it up
Originally Posted by Treflip View Post
Nice work! Subscribed!
Originally Posted by legacyej25 View Post
Awesome build so far. Subscribed as well.
Thanks guys! Can't wait to get this out on track (I haven't even taken it through the entire rpm range yet!)
Any idea how much weight you've saved so far?
I have no idea honestly, I'll have to find a place to weight it at, I'm curious as well.
Jump to top CrookedCommie is online now   Reply With Quote
Old Wed, Aug-03-2016, 06:13:51 PM   #12
CrookedCommie
Captain Slow
Bulgaria
I wanted to replace the oil pan while I had it down, so I had some time to finish up a couple more small projects.
Removed the aux fan. What a hassle removing the bumper and trim. This should get some more airflow through the radiator at speed.
Turner pulleys, easy install, except for torquing the alternator pulley nut down.
Pressing in the AKG FCAB 75D, press comes in handy.
BW VANOS Line:
SS Clutch line:
AKG Solid Steering Coupler. This was a bit tricky - you need to punch or drill out the rivets on the OEM and bolt it up. I gave up trying to punch the rivets out and just drilled right through the head while trying my best to center it. Reconnect this before you bolt on the steering rack, the fit is very tight!
Reused the Hotchkis sway bar from my 330i. I'm not sure what the differences are, but the fit looks correct. Clearance to wheels is fine as well. Installed new PS line and reservoir.
New oil pan with pickup tubes, also replaced the oil separator line with the newer AN SS version (expensive!). Installed AKG 75D Engine Mounts.
Finally got a set of track wheels! Apex ARC-8 17x10 ET25, here they are with a set of 275 NT-01's squared.
I'm driving the car around this week to double check everything. Will be taking a short break while I'm in Europe for work (and Nurburgring!).
Old Wed, Aug-03-2016, 06:20:26 PM   #13
legacyej25
Reputation: 0 legacyej25 is on a distinguished road
Those tires look meaty, what specs are they?
2002 Carbon Black on Cinnamon
Jump to top legacyej25 is offline   Reply With Quote
Old Wed, Aug-03-2016, 06:23:53 PM   #14
CrookedCommie
Captain Slow
Bulgaria
275/40/17 NT-01 squared. They touch the front wheel liner when turned
I bought the car with the rear fenders rolled, I'm probably going to roll the fronts as well "just in case". So far it looks like these fit ok, but I still need to drop the rear ride height I think.
Old Wed, Aug-03-2016, 08:47:37 PM   #15
OneFastSicilian
Frankie
OneFastSicilian's Avatar
Italy
hows the car feel with 17s? it looks awesome by the way!!
Previous:
  • 01 - AW/IR - Sold
  • 03.5 - IR/Impulse - Sold
  • 02 - TiAg/Blk - Sold
  • 05 - IB/Blk ZCP - Sold
  • 02 - LSB/Blk - Sold
  • 05 - SG/Blk - Current!
Check out my Journal!
*Instagram*
@E46m3_Owners_OTW
Jump to top OneFastSicilian is offline   Reply With Quote
Old Wed, Aug-03-2016, 09:46:39 PM   #16
CrookedCommie
Captain Slow
Bulgaria
Thanks! Honestly, it feels more compliant then the 19's with all seasons that came with the car, despite the stiffer sidewalls of the NT-01's.
Old Thu, Aug-04-2016, 09:46:32 AM   #17
Flow
Flow's Avatar
France
Awesome build ! Someday I'll do the same with an E46
2004 M3 TiAg / LSB SMG
Old Thu, Aug-04-2016, 05:43:31 PM   #18
CrookedCommie
Captain Slow
Bulgaria
Merci Flow! Your pictures from the Spanish rally look amazing, very jealous. I love the south of France, need to visit again soon.
Old Thu, Aug-04-2016, 06:35:56 PM   #19
Tom_schleg
Reputation: 0 Tom_schleg is on a distinguished road
What are your thoughts on the pulleys?
Jump to top Tom_schleg is offline   Reply With Quote
Old Thu, Aug-04-2016, 06:44:26 PM   #20
CrookedCommie
Captain Slow
Bulgaria
I'm not sure if I could notice any power difference because I installed at the same time that I got rid of a bunch of weight. The main reason for getting them was to under-drive the PS and water pump, since it'll stay in high RPM's on track. For $250-$300, I wouldn't put it as a must-have, but nice-to-have (and TMS was running a sale).
Discussing CrookedCommie's Track/Street Build in the Member Journals Forum - Do you have a long term project you would like to share with the community? Use this forum to create a single thread which you can update over time to document the progress. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
