Old Mon, Apr-30-2012, 10:23:40 PM   #21
///NNM
///NNM's Avatar
Reputation: 0 ///NNM is on a distinguished road
Russian Federation
Default Re: DIY e46 M3 Engine Mounts
Originally Posted by ///NNM View Post
when you are lifting the engine, you are risking to break the heater hoses... or pull some other cables.
lowering the subframe is much better route IMHO.
i set the engine on engine holder and lowered subframe, replaced mounts and put subframe back - 1 hour job and i didn't take anything else off.
use this:
http://www.harborfreight.com/1000-lb...bar-96524.html
hint: taking off wheels will remove much tension from the control arms, so when you lower the subframe, it will be free from the force of gravity of the wheels pressing the control arms up into the subframe. simply put, take off the wheels.
fyi: you WILL need ALIGNMENT if you move any suspension parts, which you will do while moving the subframe.
i got lifetime alignment, so i didn't care about that.
Jump to top ///NNM is offline   Reply With Quote
Old Wed, Jul-11-2012, 05:10:56 AM   #22
05_r6
Reputation: 0 05_r6 is on a distinguished road
So you can replace subframe mounts out too then? Hell, prolly be good just to do them all while your down there.
Jump to top 05_r6 is offline   Reply With Quote
Old Fri, Jul-13-2012, 03:01:45 AM   #23
skelzy
Great White
skelzy's Avatar
Reputation: 0 skelzy is on a distinguished road
So reinstalling mounts and Bentley shows three different torque values for the M12 subframe bolt. It's the bottom value (subframe to body). Which grade is our bolt?? That is a large range of values and I don't want to strip anything... Anyone know?
Sent from my iPhone using my fingers
2005 Coupe AW/BLK/SMG/LOADED
Jump to top skelzy is offline   Reply With Quote
Old Fri, Jul-13-2012, 04:34:40 AM   #24
skelzy
Great White
skelzy's Avatar
Anyone????
Old Fri, Jul-13-2012, 12:35:31 PM   #25
skelzy
Great White
skelzy's Avatar
I'm gonna take a stab in the dark and say they upgraded the bolt over time and the last one shown (12.9 grade) is the newest so I'm using the 77 ft/lbs torque.... It's in the middle of those torque values anyway....
Old Fri, Jul-13-2012, 01:10:50 PM   #26
mpower22
CPV O-Ring Guy
mpower22's Avatar
Sorry no one's gotten back to you on this. I've seen the posts hitting, I've just been moving around a lot the past few days. The 12.9 isn't an "upgraded" bolt per se, these different grades of steel are used specific to their application. Typically bolts of this strength have the grade stamped right on the head of the bolt. Have you checked that? I'm pretty sure the subframe reinforcement plate bolts have it, but I can't recall about the subframe bolts themselves even after I just reinstalled my CSL headers just a few months ago. Those bolts are AT LEAST a 10.9, they may be a 12.9... Again, just check the bolt head. Either way, for a bolt such as this you're only looking at a 4lb difference in the torque.. not really that critical of an issue. Just set it in between if you can't find out and you'll be good to go. Hell, most people on here don't even use a torque wrench for the plate bolts, although I do.
///M3 - Dream Car 11/18/02 - 11/17/17
15-Year Forum Member
2003 M3Laguna Seca Blue/6MT Black Leather Cloth Interior/Full [CSL] Exhaust
Old Fri, Jul-13-2012, 02:05:09 PM   #27
skelzy
Great White
skelzy's Avatar
Your the man You were right, 10.9 stamped right on head of bolt. Duh, how did I miss that? Thanks so much for the feedback...
Old Mon, Aug-13-2012, 10:20:45 PM   #28
duracellttu
Thanks for the write up, I'm about to do this install this weekend with the bimmerworld performance engine mounts.
One question about jacking up the engine for the mount swap. Are you not at risk of damaging anything in the transmission or drive shaft when you lift the engine? is there that much play in that line to not do any damage?
Also, any recommended torque specs for the engine mounts?
2005 BMW M3 ZCP - Black/Black 2M Autowerks Full Restoration: RKP CF Roof Conversion, OE CSL Trunk, JCSL Diffuser
Paul Claudes Custom Tune | Kassel Performance CSL ECU Conversion+MAP Sensor | Lang Stage Stage 2.5 Head | 288/280 Schrick Cams+DLC Coated Followers | CSL Karbonious Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91 w/ 3 stage clutch
TCK SA 450/500 | Vorshlag Camber Plates | Rogue Engineering ASP, RSM | AKG FCABs, RTABs, SFBs | TMS Sway Bars, Camber Arms, Pullies | Mason Race Strut, Rear X-Brace | AS 30% SSK | SPAL Fan | Redish Reinforcement | Turbo Toys V2 Hub | WPC Treated Rod Bearings
Old Sat, Jan-12-2013, 01:45:11 AM   #29
bmwJohhnyD
user formerly known as bmwbob
bmwJohhnyD's Avatar
United Nations
bump for good questions!!
Old Sat, Jan-12-2013, 01:53:25 AM   #30
¿safxtacy!
Who are we?
¿safxtacy!'s Avatar
Reputation: 0 ¿safxtacy! is on a distinguished road
Pakistan
No the drive shaft will flex enough. When I did mine however I had to loosen the transmission brace a little.
“You have brains in your head. You have feet in your shoes. You can steer yourself any direction you choose.
You're on your own. And you know what you know. And YOU are the one who'll decide where to go...”
Jump to top ¿safxtacy! is offline   Reply With Quote
Discussing DIY e46 M3 Engine Mounts in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
