Old Fri, Jul-06-2018, 02:52:32 AM   #1
10speed
Reputation: 0 10speed is on a distinguished road
Default What pulls timing on the S54?
I am in the process of having my car tuned after adding the Evolve CF airbox. The car has been on the dyno twice, having remote tuning done. So far, we have about 4 hours into it. The problem is, the car is just not making the power we are expecting.
Previously, mods were SS V1 headers and S-Pipe, SS section 2, OEM muffler, Epic tune, pulleys, stock airbox, alpha-n maf delete with 4" intake. 325hp/245tq on a dynojet.
Went to the same dyno with everything else the same except for the Evolve CF airbox and swapped in the OEM section 2. Car was way down on power. Somewhere around 315/235. The IATs were really high. The intake wasn't able to get any good cool air. Other ideas were the knock sensors may have been faulty. Also, checked the part number on the IAT sensor.
Swapped in new knock sensors, e36 M3 IAT sensor, built a heat shield for the airbox and ran three 3" ducts from the front bumper. IATs are now +1-3 degrees ambient, so got that covered. Did quite a lot of 3rd gear pulls with BMWlogger and forwarded those logs to the tuner. Tuner verified car was still down on timing. Put 100 octane in it and ran more logs. The car responded with improved timing yet, not quite where it should be. Decided to put 92 octane back in it and hit the dyno again.
The results of that dyno session were 321/248. I asked him to tune for more torque. Should still be running more timing than it is. We are down to a couple things now, faulty DME, or possibly the airbox is so loud or vibrating so much that it is interfering with the knock sensors.
Thoughts?
Jump to top 10speed is offline   Reply With Quote
Old Fri, Jul-06-2018, 07:20:24 AM   #2
mrgizmo04
mrgizmo04's Avatar
Default Re: What pulls timing on the S54?
Assuming your tune is optimized for 91 or whatever is available in your area? Some tune it for 93 or above, so double check.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Fri, Jul-06-2018, 11:52:14 AM   #3
geargrndr
Working for Nefarious Porpoises
Reputation: 0 geargrndr is on a distinguished road
Interesting. Few thoughts...
Some believe that the "CFracecarairboxCSL!!!" gains are relatively BS / minimal. I know one tuner who is emphatic about that actually and thinks the CSL airboxes are a ridiculous waste of money. (they do look and sound awesome tho'.... ) so... are you sure your expects aren't too high?
In addition, I've seen some BTB tuning of various S54 cars and started to really believe in the (somewhat surprising) importance of big exhaust. There was one track rat car around here that made loads more power than it should, given its other (relative lack of) mods, and the one big difference was a massive exhaust. So maybe your OEM section 2 reversion is really hurting you?
Lastly, your 'base line' 325whp is, as you prob know, super strong. Thats a good number. Gonna be hard to beat that with less-exhaust + CF airbox... again... expectations...
I doubt your KS were bad BTW. And extremely doubt a bad DME. Esp when the car is otherwise making great power, just not quite as much as you're hoping for. These things are really robust little computers. I suppose the question about the vibration and the KS is valid maybe... But for that mod list a 320-325whp number seems roughly right to me?
2003 M3CicM6 TiAg
2002 540iT Sport Vortech S/C 6MT LSD TiAg
2008 Audi A3 2.0T DSG (hers)
1999 Cherokee Sport 4L (trailer-hitched in-law loaner bomber)
Recently Former...
1995.5 Audi S6 Avant (utility/winter billetturbobattlewagen)
Jump to top geargrndr is offline   Reply With Quote
Old Fri, Jul-06-2018, 03:23:31 PM   #4
Tchleung
Reputation: 0 Tchleung is on a distinguished road
I would swap the section 2 back in and go from there. It's almost the last step really to mimic true before and after results.
And is this the same tuner as you were before with factory air box...?
Follow me on Instagram @tommtomm84
09 X54.4 - Parts Hauler/Daily
02 Carbon Black M3 6MT - Fun Car
462whp/311wtq @ 9.5psi(SuperFlow)
Now at 11 PSI...
4.10 / Headers / ESS VT2-550+
Jump to top Tchleung is offline   Reply With Quote
Old Fri, Jul-06-2018, 04:16:37 PM   #5
geargrndr
He said before he was on Epic tune, then given the reference of BMWLogger, I'm going to guess after maybe is TTFS since Frank is the dude who is most known to use that for remote-tune-tweaking...
2003 M3CicM6 TiAg
Recently Former...
Old Fri, Jul-06-2018, 05:56:44 PM   #6
10speed
92 fuel, tuned specifically for this fuel.
Good feedback here. I mostly agree with you. I figured could be HP +10. There has been some talk of the OEM sec. 2 and the SS sec. 2 being roughly the same in regards to performance. So I sold it off and went back to OEM. Didn't back to back dyno test that though.
I plan on either a 3.5" single or 2.5" duel from the sec. 2 back, now that the car will be driven less on the streets and trailered to the track.
Same tuner and dyno for everything. Randy and Epic Motorsports.
Randy at Epic suggested we do 3rd gear pulls to evaluate the timing. That's the main thing that seems off at this point.
Old Fri, Jul-06-2018, 07:28:59 PM   #7
95bullet
95bullet's Avatar
Reputation: 0 95bullet is on a distinguished road
Do you know how much timing you are running?
Jump to top 95bullet is offline   Reply With Quote
Old Sat, Jul-07-2018, 01:36:59 AM   #8
10speed
I'll check when I get home tonight. I used BMWlogger on all my dyno runs.
Old Sat, Jul-07-2018, 08:38:53 AM   #9
10speed
16 degrees climbing to 23 degrees between 3000-6000 RPM.
Then a drop.
16 degrees climbing to 20 degrees between 6000 - 8000 RPM.
Old Sat, Jul-07-2018, 03:59:02 PM   #10
10speed
Discussing What pulls timing on the S54? in the Coding and Tuning Forum - Discuss all avenues of coding and tuning here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
