Old Mon, Jun-18-2018, 05:05:49 PM   #1
mikerob
mikerob's Avatar
Reputation: 0 mikerob is on a distinguished road
Default Temperature Gauge Coding
I read in one thread somewhere that the temperate gauge is designed to more or less sit at the 12 o'clock position if the water temperature is between a certain temperature band. I also recall in the post there was a way to remove or tighten this band so that the needle reacts more to changes in water temperature. But I can not recall where I read this.
I believe the changes had to be made in the IKE EPROM hexadecimal fields via PASoft
Can anyone point me to this thread - or post a procedure for this.
Thanks
Mike
Cary, NC
Current Ride
- 2006 BMW M3 Cabriolet, Euro Headers and Cats, SuperSprint Sport Exhaust, 3.91 Gears, ZCP Front & Rear Brakes, TTFS Tune, Euro Headlight Switch
Past Ride
- 1991 BMW 325i (E30) Cabriolet, Stock European Exhaust (w/o Cat), Bilstein Shocks and Struts, Hella Ecode Headlights
- 2000 BMW 323i (E46) Sport Touring, 330i Front Calipers & Rotors, Bilstein Shocks and Struts, SAP Delete, Sirius Receiver, HID/Projector Headlights.
- 1994 BMW 325is (E36) S50 Engine, Schrick Cams, Custom Chip, 3.46:1 LSD Final Drive, 330i Front Calipers & Rotors, (Lots of Modifications)
- 1987 BMW 325is (E30) European ECU and Camshaft, M3 Suspension, Headers with Custom Exhaust.
Jump to top mikerob is offline   Reply With Quote
Old Mon, Jun-18-2018, 07:05:17 PM   #2
Default Re: Temperature Gauge Coding
The e46 M3's buffer is tiny compared to other BMWs-- very minimal benefit to be had here.
Old Tue, Jun-19-2018, 12:01:31 PM   #3
geargrndr
Working for Nefarious Porpoises
Reputation: 0 geargrndr is on a distinguished road
here's the old thread, but as Ian says, the M3 is only 10 degrees in that 'buffer zone', so its not really in need of tweaking. you can validate this from the fact that the needle DOES move slighlty during driving condition changes, vs other BMW's where its just glued to the center unless the car is either stone cold or on fire.
http://forum.e46fanatics.com/showthread.php?t=1013600
2003 M3CicM6 TiAg
2002 540iT Sport Vortech S/C 6MT LSD TiAg
2008 Audi A3 2.0T DSG (hers)
1999 Cherokee Sport 4L (trailer-hitched in-law loaner bomber)
Recently Former...
1995.5 Audi S6 Avant (utility/winter billetturbobattlewagen)
Jump to top geargrndr is offline   Reply With Quote
Old Wed, Jun-20-2018, 04:19:10 AM   #4
Not only is the buffer 10 degrees, but the S54 has a tendency to rest a little bit before the buffer zone starts (buffer is from 85 - 95 C, M3 likes to hang out around 83C IME). So that needle will move a decent bit in day to day driving.
Old Wed, Jun-20-2018, 07:44:24 PM   #5
mikerob
mikerob's Avatar
Thanks guys for your comments. Looks like I will try out my new PASoft cable and software by doing the Speedometer Error Reduction....instead of this Temperature Gauge Reset.
Any comments to my other thread regarding the Auto Leveling to Manual Leveling LCM Modification?
Mike
Cary, NC
Current Ride
Past Ride
Discussing Temperature Gauge Coding in the Coding and Tuning Forum - Discuss all avenues of coding and tuning here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
