Old Thu, Jun-14-2018, 06:35:46 PM   #1
e36 323ti
e36 323ti's Avatar
Reputation: 0 e36 323ti is on a distinguished road
Norway
Default Exhaust Gas Temperatures (EGT)?
In my airVent Display I have the opportunity to show the Exhaust Gas Temperature (EGT).
The value shown in the airVent Display is identical to the value read by Tools32.
According to Tools32 the EGT is represented by one byte with 1:1 conversion.; i.e 0-255 degC.
Measuring the EGT sensor between p5 and p10 on the MSS54-X60002 reads 217 Ohm @~20degC.
During normal driving the EGT is in the range 10-30 degC.
I would have expected the EGT to be lot higher than that.
Any opinions/knowledge?
Jump to top e36 323ti is offline   Reply With Quote
Old Fri, Jun-15-2018, 04:05:53 AM   #2
Default Re: Exhaust Gas Temperatures (EGT)?
I don’t think the tool32 formula is correct. I’ll look it up later
Old Fri, Jun-15-2018, 07:46:49 AM   #3
jared212
Reputation: 0 jared212 is on a distinguished road
Is it an RTD with 200ohm@0c? Apporoimate observed slope 0.85ohm/deg. Standard is 0.77ohm/deg
'04 SGM/Blk|SMG|AA/FS Prima Elite kit|Hacksaw built engine w/ JE/Molnar/Supertech/ARP/lots of ceramic TBC|ID1050x injectors|Radium rail+FPD-XR|Aeromotive FPR|-6an fuel system walbro 450 e85|RMS headers|Magnaflow custom 2.5" sec1|Besian|Redish|ZCP springs/Koni's|Hotchkis front sway bar+deleted rear|Turner Pulleys|Southbend stg 3 DD clutch|Innovate/Spek gauges|relocated SMG|Mishi OCC|Koyo Radiator|CSF oil cooler|basically stock interior and exterior
Jump to top jared212 is offline   Reply With Quote
Old Fri, Jun-15-2018, 02:39:27 PM   #4
ctres
ctres's Avatar
Reputation: 0 ctres is on a distinguished road
EGT should be around 500C.
Jump to top ctres is offline   Reply With Quote
Old Fri, Jun-15-2018, 05:22:46 PM   #5
geargrndr
Working for Nefarious Porpoises
Reputation: 0 geargrndr is on a distinguished road
Ha ha yeah some equation must be wrong. I assume that's happening in the DME itself, and there's not some part of the EDIABAS files that do units conversion or anything like that?
As menched, should be 500-600ish in C.
2003 M3CicM6 TiAg
2002 540iT Sport Vortech S/C 6MT LSD TiAg
2008 Audi A3 2.0T DSG (hers)
1999 Cherokee Sport 4L (trailer-hitched in-law loaner bomber)
Recently Former...
1995.5 Audi S6 Avant (utility/winter billetturbobattlewagen)
Jump to top geargrndr is offline   Reply With Quote
Old Fri, Jun-15-2018, 06:55:01 PM   #6
e36 323ti
e36 323ti's Avatar
Norway
The conversion is done in tools32 and not in the DME.
The temp sensor location (item 8) is just before the cat inlet:
Old Sat, Jun-16-2018, 05:25:00 PM   #7
e36 323ti
e36 323ti's Avatar
Norway
Yes, most likely a PT200.
I think you are correct.
I hooked up an MSS54HP in my bench and attached a Fluke Process Calibrator to the EGT input on the MSS54HP. Read the KBUS respons when varying the resistance (effectively simulating the EGT sensor). Could then map resistance to the values reported via the KBUS.
Next I used the Callendar-Van Duesen equation solved for T>0 and calculated the tempearatures from the resistance values (T_CVD).
Finally I looked up the datasheet for an Amphenol PT200 EGT (pdf link) and compared with my result.
The temperatures calculated from the Callendar-Van Duesen equation shows increments of 15.7 degC in average. Comparing the calculated T_CVD, the data from the Amphenol PT200 EGT and KBUS*16 it is clear that the EGT is a PT200 as well as that the Tools32 formula is incorrect. Multiplying the KBUS values by 16 seems like an appropriate solution...
Another lesson learned is that if the resistance goes above 944 Ohm or below 174 Ohm the MSS54/MSS54HP reports error.
After updating the airVent Display software with the above findings, the EGT now shows expected values.
I think I conclude with problem solved :-)
Discussing Exhaust Gas Temperatures (EGT)? in the Coding and Tuning Forum - Discuss all avenues of coding and tuning here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
