Old Mon, Feb-15-2016, 08:52:52 PM   #1
ac427
Reputation: 0 ac427 is on a distinguished road
United Kingdom
Default Generating full and partial ECU tunes from daten files
I would like to generate the OEM CSL binary from the original BMW utilities.
I could just download the CSL file from Paffy's site but i would like to know how to compile the binary for my own knowledge.
Do i just need the BMW utilities and the latest daten files to do it?
Jump to top ac427 is offline   Reply With Quote
Old Tue, Feb-16-2016, 06:22:21 AM   #2
NZ_M3
Reputation: 0 NZ_M3 will become famous soon enough
Default Re: Generating full and partial ECU tunes from daten files
Which version do you need!?? I can create every single version you want with a generic vin number and no ews info and perhaps post the lot up for everyone??
Jump to top NZ_M3 is offline   Reply With Quote
Old Tue, Feb-16-2016, 11:35:32 AM   #3
paulclaude
paulclaude's Avatar
Reputation: 0 paulclaude is on a distinguished road
Scotland
Sounds good
I would also be interested in knowing how these are generated from the datens though.
Jump to top paulclaude is offline   Reply With Quote
Old Tue, Feb-16-2016, 11:47:17 AM   #4
cossie1
Reputation: 0 cossie1 is on a distinguished road
United Kingdom
and me
Jump to top cossie1 is offline   Reply With Quote
Old Tue, Feb-16-2016, 02:15:40 PM   #5
SliM3
SliM3's Avatar
Populating a tune from daten files is pretty easy, but paffy's file includes the specific boot sector for CSL; which is why you couldn't use WinKFP for the flash process.
For the longest time we had no access to a CSL DME boot sector until the guys cracked it. As big, and somewhat unorganized as that mega thread is, we got into this a couple years back. A lot of "prerequisites" had to come to fruition, and the stigma that the DME could never be hacked by non-tuners dismissed.
I took so many notes back then it's ridiculous, but here's a "cliff notes" excerpt from one of terra's posts concerning the data/program section breakdown, circa 2013
0x0-0x3FFFF in the 0PA matches 0x10000-0x4FFFF in master (1st half of full dump). -- I should note that 0x31A67-0x3FFFF (or 0x41a67-0x4ffff in the actual dump) is blank anyway (by blank, I mean sea of FFs)
0x40000-0x7FFFF in the 0PA matches 0x10000-0x4FFFF in the slave (2nd half of full dump)
Corresponding data sections occupy 0x8000-0xFFFF in each half.
To summarize the master:
0x0-0x3FFF is the bootloader. <<<< this was the missing link to run CSL SW
0x4000-0x4800 is FF.
0x4800-0x4878(?) is the flash counter.
0x4878(?)-0x5D11 = FF
0x5D12 - ~0x8000 = AIF, VIN, possibly EWS and other identifying info
0x8000-0xFFFF = data section
0x10000-0x4FFFF = Program
0x4FFFF-0x7FFFF = FF
I haven't taken a close look at the second half yet, but I expect it to be similar.
Armed with this knowledge, I'm reasonably assured we can adapt other full dumps to run on our own DMEs without worrying about EWS. For an MSS54HP, replace 0x0-0x4000, 0x8000-0x4FFFF, 0x80000-0x84000, and 0x88000-0xFFFFF with the corresponding sections of the donor dump. (0x0-0x4000 and 0x80000-0x84000 should only differ between MSS54HP and MSS54HPCSL). Leaving the rest alone *should* leave EWS, VIN, UIF, etc... intact. Probably best to clear adaptions before actually starting the car/
///M3 '06 Carbon Black
-Benjamin Franklin
- Fuel adaptations explained
- Checksum Verification
Old Tue, Feb-16-2016, 05:29:49 PM   #6
^ One thing that should be amended is that the ISN is located at 3FE4 (or maybe 3FE6) on the slave. Didn't figure that out initially since OBD reads omit the ISN
Old Wed, Feb-17-2016, 03:57:06 AM   #7
NZ_M3
Here are all the versions and the links to download the full bins I created.
VIN is set as WBSBL12345AB12345 and there are no EWS sync data on it whatsoever - easily corrected in the bin or via tool32
Japan version
- 7837336 (7837337) - standard Jap version software
https://mega.nz/#!k5VkjI7I!TxGHMyBqL...jEFbNmMf23T5k8
- 7837338 (7837339) - v-max unregulated
https://mega.nz/#!EgVhwaDK!aDS7r8fbc..._dy_PsCgX_tTSw
EOBD Variants
- 7837328 (7837329) - standard EOBD version
https://mega.nz/#!4t9UFI5J!RJpI2mQAx...xI_IALer_fpL-8
- 7837330 (7837331) - EOBD v-max unregulated
https://mega.nz/#!RwUXgbKb!48-0tmd6V...J1knn-oVQC5GBQ
Data Record without EOBD variants
- 7837332 (7837333) - standard non EOBD version
https://mega.nz/#!Mkd0EKRY!f5vatNe_u...BLWiSDh7jGWYoU
- 7837334 (7837335) - v-max unregulated
https://mega.nz/#!QxNBAQwB!6OEYRCRmn...rSDbnApIM499lU
Old Wed, Feb-17-2016, 08:38:39 AM   #8
Hmm. Just compared the Japanese and EOBD variants, and they are nearly bit for bit identical. Only the version string and checksum differ.
Old Wed, Feb-17-2016, 08:41:59 AM   #9
cossie1
United Kingdom
I did the same with all delimited versions.
Minimal differences between all 3.
Old Wed, Feb-17-2016, 10:29:30 AM   #10
ac427
United Kingdom
Japan version
EOBD Variants
Thanks NZ_M3. How did you generate these files though ?
Sorry for being thick but what is the difference between Data Record with and without with EOBD ?
Discussing Generating full and partial ECU tunes from daten files in the Coding and Tuning Forum - Discuss all avenues of coding and tuning here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
