Old Thu, Jun-14-2018, 04:22:25 PM   #31
Volke
Reputation: 0 Volke is on a distinguished road
Default Re: RS-30 lithium battery
Originally Posted by Paulo M View Post
Yes, auto disconnect and auto start button feature on the battery itself! It does seem like a win win solution for those wanting to shed weight, regardless of their reason.
I personally donít want a lithium battery without these features.
The auto disconnect is nice because it prevents you from making an expensive mistake and ruining your battery. The Braille G20, G30(replacement for GU1R) and I'm sure many other batteries have this.
The auto restart usefulness depends on your application. The biggest benefit is it allows you to run an undersized(and cheaper) battery without having to worry about getting stranded, but at the cost of having your DME, clock, seat settings etc. reset when it happens. That's a pretty big penalty for a daily because setting your clock, seat settings and whatever frequently will get old fast, and you should just size your battery properly instead in which case you can get a cheaper option without the restart feature. On the other hand, it's a really nice feature for a racecar that has likely deleted the clock, factory electric seats, etc.
A properly sized battery really has no use for the auto restart. Unless you have some serious power draw from upgraded audio, a Braille G30/GU1R(39 Ah PbEq) is more than enough for a daily driven car unless you leave it sitting for more than 2 weeks at a time. If you do have some upgraded audio, the RS-30 with 50 Ah PbEq should be enough to replace the 60 Ah OEM battery which has some margin for error built in.
IMO, the auto restart on a RS-30 sized battery is pretty useless, but the same technology on their smaller batteries is very appealing for racecar use.
Peter
Mechanical Engineer
Jump to top Volke is offline   Reply With Quote
Old Thu, Jun-14-2018, 04:31:21 PM   #32
Nothing on the DME gets lost when it loses power, and neither do seat settings.
If you don't have something that sets the clock automatically (e.g. intravee), that could be a slight PITA.
That said, I, too, would prefer to (and do) have a sufficiently large battery that i don't have to worry about it.
I can see the allure of the final start feature, though. Leave something plugged in overnight, no problem.
Old Thu, Jun-14-2018, 05:00:02 PM   #33
Volke
Hmm... I'll have to take your word on the DME. I have not had the E46 long, and I'm used to turbo cars that have some learned parameters( ex. A/F Learning & Fine Knock Learning on the Subaru STI).
The programable shift lights & beep, reverse tone, and gear indicator on my BRZ also reset along with the clock, so I figured there's be more stuff that resets on the E46 besides the clock.
I just bought a Braille G30 that I'm installing soon, but I look forward to seeing what else is new on batteries in a few years.
Peter
Mechanical Engineer
Old Sat, Jun-16-2018, 07:21:04 PM   #34
2006E46M3fan
2006E46M3fan's Avatar
Originally Posted by Move_Over View Post
Just fabbed something up out of threaded rod and aluminum.
Thank you for the response. I'll have to fab something up as I ordered this battery and it just came in. The thing is tiny!
Jump to top 2006E46M3fan is offline   Reply With Quote
Old Sun, Jun-17-2018, 07:32:09 PM   #35
The learned parameters on the DME are stored in non-volatile memory - battery disconnect won't impact it.
You'll lose the clock, mpg/average speed calculations, and radio presets I think when disconnecting the battery
Old Sun, Jun-17-2018, 07:47:24 PM   #36
SilberFuchs
Visca el Barca!
SilberFuchs's Avatar
Reputation: 0 SilberFuchs is on a distinguished road
not the radio presets either as I found out recently after my battery was dead. clock, mpg yes
2005 TiAg/Blk M3 Coupe (6MT, Xenon, HK sound)
///Mods - performance: OE CSL airbox w/ MAP sensor, OE CSL headers (Swaintech ceramic coated) & cats, Supersprint resonated X-pipe & "Street" muffler, Schrick 280/272 cams & DLC rockers, SAP delete, ECU tune, OE CSL cabin air filter housing, Rogue Octane SSK & transmission mounts, ZHP shifter knob, hollowed CDV (Zeckhausen), Mason/GSP clutch pedal, Volk Racing CE28N 18x8.5F/9.5R wheels with 245/275 tires
///Mods - appearance: OE CSL front bumper & trunklid & diffuser, piano black kidneys & gills, Depo smoked corners, OE short center console with Euro tray, AC Schnitzer aluminum pedals, 35% tint
Jump to top SilberFuchs is offline   Reply With Quote
Old Sun, Jun-17-2018, 11:03:47 PM   #37
My GU1R mounting location. I put it under the hood because it's not doing anything meaningful for weight distro at 5.7 lbs, and the battery cable to the trunk is 8 lbs-- heavier than my battery!
Tank in front of it is my light weight, one pint washer tank. I use that because I rarely need washer fluid with how I use the car, but still don't want to be without it if I need it.
Old Mon, Jun-18-2018, 04:07:05 AM   #38
Volke
What washer tank is that? Are the battery and washer brackets custom? Did you get rid of the factory battery disconnect or relocate it to the front?
I want to run the hard motorsport race brake ducts so I need to move my washer bottle too. I've thought about moving my battery up front too, but I also want to run an oil catch can. Don't think I can fit all 3 in that compartment.
Peter
Mechanical Engineer
Old Mon, Jun-18-2018, 11:06:24 AM   #39
That's the e39 high intensity washer tank. I had it sitting around from when I removed it from the M5, but it's actually a perfect fit in the area-- it actually wraps around the battery
It also is designed to work with the same pump as the e46, so it's plug and play with our wiring harness.
I kept (and relocated) the factory battery disconnect feature, as well as the huge chassis fuse.
Tank looks like this:
Old Mon, Jun-18-2018, 06:38:03 PM   #40
usdmej
is that battery mount custom or available to purchase?
Jump to top usdmej is online now   Reply With Quote
Discussing RS-30 lithium battery in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
