Old Wed, Mar-14-2018, 04:44:31 AM   #1
Daily Driver
Reputation: 0 Daily Driver is on a distinguished road
Default Injector flooded cylinder - Long term problems?
I was driving my 2003 to work yesterday when the EML light came on and the engine went into limp mode. I pulled over within 1/2 a block. Turned off the engine, and it failed to restart. No problems turning over.
I had it towed to my Indy where they let me know that the cylinder was full of gas but there was no issues. I had the oil changed.
Do you think there will be any long term damage to the engine such as head gasket issues?
Jump to top Daily Driver is offline   Reply With Quote
Old Wed, Mar-14-2018, 04:52:50 AM   #2
Drewster
Drewster's Avatar
Default Re: Injector flooded cylinder - Long term problems?
If it didn't bend a rod and still has compression? No.
Old Wed, Mar-14-2018, 06:44:29 PM   #3
M3_#67
Reputation: 0 M3_#67 is on a distinguished road
Like drewster said you should be fine. You did the right thing pulling over. You might have done damage if it started and ran for a long period with it running the stuck injector pouring in fuel and washing the cylinder (loss of compression) and then hydro-locking (bending the rod). Your Indy look into why it did what it did?
'02 Imola Red on Black
Jump to top M3_#67 is offline   Reply With Quote
Old Thu, Mar-15-2018, 06:01:03 PM   #4
bigjae1976
Should be fine.
I wonder how common a fuel injector failure is.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Thu, Mar-15-2018, 06:53:06 PM   #5
Originally Posted by bigjae1976 View Post
Should be fine.
Not that common, given how many threads we see about it.
Old Fri, Mar-16-2018, 05:10:43 AM   #6
bimmerdriver
Stuck injectors aren't very common, but they do happen. I know someone with an Audi V6 that had this happen. They pulled over right away and the engine seemed to not have any problems. It's definitely not a good thing, however. I'd recommend you get all of the injectors cleaned and tested.
Old Fri, Mar-16-2018, 08:40:11 PM   #7
nrubenstein
Not a problem if the engine wasn't damaged.
...assuming that they have replaced the injector.
Old Sun, Mar-18-2018, 03:01:39 AM   #8
Daily Driver
As the OP, here is what my Indy said.... this is very uncommon. They might see one every couple of years.
I have the car back with one new injector and the others cleaned. Car runs well, and a bit smoother. BTW, I had noticed a drop off in fuel mileage for about 300 miles before it quit altogether.
Discussing Injector flooded cylinder - Long term problems? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
