Old Wed, Mar-14-2018, 01:17:23 AM   #1
SlickmisterN
Surrounded By Grapes
SlickmisterN's Avatar
Reputation: 0 SlickmisterN is on a distinguished road
Greece
Default Help finding spot for interior switch.
Hey so there appears to be no "blanks" or obvious locations to mount an auxiliary switch in the cabin.
Any suggestions or examples? The switch in question is a momentary DPDT switch to control exhaust dump/butterfly valves. It is exactly 1-3/4" long x 1" wide x 1- 1/2" deep.
The depth has been the killer finding a spot. Ideally it would be great to have it under and to the side of the e-brake handle but im not sure there is enough clearance for the body underneath. Its way too deep for ash tray mounting of any kind and being able to close the lid.
I have the euro center console with slide top storage and no armrest...
Jump to top SlickmisterN is offline   Reply With Quote
Old Wed, Mar-14-2018, 04:15:16 AM   #2
04yfz
Default Re: Help finding spot for interior switch.
I have one in my ashtray for the same purpose, works perfectly. You can also put it behind the cupholder in the cubby thats part of the coinholder.
Pat
Old Wed, Mar-14-2018, 05:55:55 AM   #3
kokgo20
kokgo20's Avatar
Use a wireless remote, you can even sync it with your garage door opener buttons, that's my plan when i install mine.
Build thread
Old Wed, Mar-14-2018, 06:23:49 AM   #4
SlickmisterN
Greece
Holy crap, that is a great idea. It does have the fob that opens and closes it all the way but I was thinking having a hardwired switch somewhere accessible in the cabin would allow me to adjust just how much open/closed I want it, and for optimum sound tuning.
But yea thanks for the idea. I really hope it works.
Old Tue, Mar-20-2018, 07:34:36 AM   #5
SL Blak Soldier
Doooorrrifttt
Reputation: 0 SL Blak Soldier is on a distinguished road
i like my secret switches on the knee panel under the steering column. Its easily removable so you can wire up any switches quiet nicely.
Oxford Green/Cinnamon 6spd - Garage 54 | Unique Auto Films | 13th Letter | MiniCorsa | Speed District
Jump to top SL Blak Soldier is offline   Reply With Quote
Old Tue, Mar-20-2018, 07:53:13 AM   #6
lmtfi
lmtfi's Avatar
I have an AE switch installed by my left knee.
Old Tue, Mar-20-2018, 07:56:56 AM   #7
SlickmisterN
Greece
Got everything wired up under the car. The ash tray was the best place I decided after finding a smaller switch.
I guess my motors brain runs on a different frequency then any garage door opener. Couldn't get it to pair/sync with the HomeLink. Oh well, the key fob and ashtray button will be plenty.
Old Tue, Mar-20-2018, 10:50:03 PM   #8
SlickmisterN
Greece
Old Tue, Mar-20-2018, 11:57:44 PM   #9
ultimatemj
Late to the discussion, but here is a pic of the switch I added for my Valentine1.
There was a decent amount of room under the trim panel~
Old Wed, Mar-21-2018, 03:59:59 PM   #10
CrookedCommie
Captain Slow
CrookedCommie's Avatar
Bulgaria
Attachment 209152
I did similar for a laser jammer kill switch - exact same type of button as yours, but I found a blank trim piece from an E39 that is the exact same dimension as the mic panel on the right there, and put the button in that. Looked 100% stock except for the green LED.
Jump to top CrookedCommie is online now   Reply With Quote
Discussing Help finding spot for interior switch. in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
