Old Tue, Mar-13-2018, 10:39:36 PM   #1
ultimatemj
Default Key problem, trunk problem, or valet setting?
1) Both my keys had dead batteries from June to Jan.
I ordered some replacement batteries, cut one key open, soldered the battery in, and paired it with the car. From the key: Central locking and door unlocking work again. Trunk unlocking does not. Interior footwell trunk button does work.
2) I installed an OE CSL trunk over the 2017 holidays...no handle with button.
Now I have to use the key in the lock to open the trunk, or the footwell switch.
a) possibly I put the key back together improperly
b) possibly the trunk isn't wired properly
c) possibly it is in the hard to understand valet mode
Thoughts? In what order would you debug this situation?
Thanks in advance.
Discussing Key problem, trunk problem, or valet setting? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
