Old Tue, Mar-13-2018, 09:20:54 PM   #1
Newswartz
Newswartz's Avatar
Reputation: 0 Newswartz is on a distinguished road
Default Smg paddle delete? aftermarket wheel?
Saw this today on a show car e46 M3. Appears as though he has an smg and put an aftermarket wheel on. It never occurred to me before that this would actually work but you would need to drive with the shifter only? Maybe someone can post the picture. Strange
https://imgur.com/a/n3iV1
http://www.m3forum.net/m3forum/image.php?type=sigpic&userid=215618&dateline=15216  66489
Dinan Samco RPI Rogue TTFS
iForged Mason Turner H&R Hawk
AKG Redish H&R ST StatusGruppe
Jump to top Newswartz is offline   Reply With Quote
Old Tue, Mar-13-2018, 10:55:02 PM   #2
CSLGav
CSLGav's Avatar
Reputation: 0 CSLGav is on a distinguished road
Default Re: Smg paddle delete? aftermarket wheel?
Yes shifter only. And it looks terrible.
Jump to top CSLGav is offline   Reply With Quote
Old Wed, Mar-14-2018, 02:14:29 AM   #3
avusblu_e36
That poor car, the interior trim painted galaxy metallic barf.... air suspension and I'm SURE it has like orange wheels.
Also why would you want to do this? the oem paddles are so small anyway, it's just headache, cost, and you lose the ability to hold the left paddle to use the hill hold function.
Jump to top avusblu_e36 is offline   Reply With Quote
Old Wed, Mar-14-2018, 02:15:47 AM   #4
avusblu_e36
also I'm the hudson valley as well!
Old Wed, Mar-14-2018, 03:05:42 AM   #5
Joefresh
Joefresh's Avatar
Reputation: 0 Joefresh is on a distinguished road
Works Bell makes a steering wheel quick release with paddle shifters.
check out my artwork
www.instagram.com/TOADesign
Jump to top Joefresh is offline   Reply With Quote
Old Wed, Mar-14-2018, 03:14:12 AM   #6
04yfz
The paddles are just electric switches, smg can work perfectly fine without them.
Pat
Old Wed, Mar-14-2018, 04:37:07 AM   #7
hikkakaru
Reputation: 0 hikkakaru is on a distinguished road
the other option is to use an aftermarket wheel that has an accessory plate readily available, or make your own (they are usually just flat, just make a cardboard template and cut it out of whatever material you have on hand).
Most off-the-shell accessory plates would be uncomfortable for the constant use the paddles see -- but if you make your own plate then you can accommodate yourself however needed.
The Works Bell solution is really nice, but its $$$ and it requires the use of a boss that extends the wheel out further from the column. The switches on it feel really nice, though.
if I were to make my own like the picture attached i'd place the shifter buttons closer to driving hand positions.
File Type: jpg Sparco_Steering_Wheel_with_Harness_1024x1024.jpg (79.6 KB, 10 views)
Jump to top hikkakaru is offline   Reply With Quote
Discussing Smg paddle delete? aftermarket wheel? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
