Old Tue, Mar-13-2018, 09:00:50 PM   #1
mrgizmo04
mrgizmo04's Avatar
Default EWS immobilizer
Hey mates,
Recently scanned the car and found this 0F code in EWS Vehicle Immobilizer for "Voltage supply, EWS3 control module".
Around same time as I replaced the battery in the car, started getting code 90 for "Battery voltage: open circuit" in ZKE Central body electronics.
Is this the key transponder dying on me, or something else?
Appreciate the insight.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Tue, Mar-13-2018, 11:54:41 PM   #2
Default Re: EWS immobilizer
Car battery might just be getting old. Otherwise I'd check for a short circuit or popped fuses (particularly any that might be common between the EWS module and the GM5)
Old Wed, Mar-14-2018, 12:45:01 AM   #3
mrgizmo04
mrgizmo04's Avatar
Just replaced the car battery right before getting these codes...It seems to be around 12.56V when sits overnight or two, when running, it's around 13.84V, so seems ok there, or is that in the lower range of what a healthy battery is expected to put out?
Got this one, if that matters: https://www.autozone.com/batteries-s...19458_300932_0
'05 M3 6MT coupe
Discussing EWS immobilizer in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
