Old Tue, Mar-13-2018, 01:28:12 PM   #1
elcidce91
Reputation: 0 elcidce91 is on a distinguished road
Default Aux Cable Volume Problems
I have a 2003 Convertible with factory navigation with Harmon Kardon. In December I installed a BMW Aux cable into the radio. I installed it into the wire harness in the back of the radio. I added the aux connection into the ash tray bottom. I was using a bluetooth adaptor to play music through the Aux cable. After a few weeks the volume on the Aux input from my phone was very low. I cant hear it well over the noise when the car is running. The regular radio and CD player still work correctly.
I checked the bluetooth volume on the phone, and the volume of the stereo, but it didnt help. I bought a straight plug to play the phone into the Aux cable and it didnt seem to fix it.
Before I take the radio out to check the connection in the dash is there anything I could have missed?
Thanks
Jump to top elcidce91 is offline   Reply With Quote
Old Tue, Mar-13-2018, 03:28:49 PM   #2
silvergray545
silvergray545's Avatar
Default Re: Aux Cable Volume Problems
My AUX volume is very low, as well. I have to crank up the stereo to get to a normal volume level. I installed mine in 2015 and never looked into it. Just assumed that's how it works.
2004 BMW M3 6MT - TiAg/Gray
2016 BMW M3 ZCP 6MT - AW/SO
2014 VW GLI 6MT - Black/Black
Instagram
E46 M3 Build Journal
Old Tue, Mar-13-2018, 04:00:54 PM   #3
JamesSJ1
Reputation: 0 JamesSJ1 is on a distinguished road
I have this same aux input, and like others the volume is low compared to the radio levels. The obvious part is that for line output on your phone, you should have the volume at max on the phone. You've probably already done that, so moving on...
Some devices have different line level outputs for the aux. One of my phones a few years ago had two options, and by selecting the high output option it balanced the volume levels between the radio and the aux input. I think that's the level the radio is expecting, whereas your phone is expecting to output for headphones first, aux second. A couple of my phones, including my current one, did not have anything like this in the settings.
For your particular situation, if you have the volume on your phone cranked 100% on a wired connection and you're still getting very low volume, I'd check the plug connection. I had a few times where the volume would just drop super low, like what you're describing, and just from pulling the stereo, pulling the cable out and re-inserting, everything has been fine for over a year since. Not sure if there is a reason for it, just saying that it helped.
Jump to top JamesSJ1 is offline   Reply With Quote
Old Tue, Mar-13-2018, 05:35:31 PM   #4
oceansize
oceansize's Avatar
OP, I'm sure you did but to just make sure, did you adjust the Auxillary Line Level on the head unit all the way up?
2003 M3 Convertible SMG w/Hardtop
KW V2 Coilovers
ESS VT1-475 Gen 3 Supercharger
Stoptech Brakes
MRR GT-1 Wheels
TTFS SMG Tune
Rogue Eng. Diablo Exhaust w/ SS Tips
Rogue Eng. Rasp Pipe
Redish Reinforcement Plates
Polyurethane Rear Subframe Bushings
Polyurethane Differential Bushings
Beisan Oil Pump Disk
Old Tue, Mar-13-2018, 06:13:50 PM   #5
JamesSJ1
I have the same factory Nav as the OP, and I've never seen an Aux line level control on the head unit controls. Is this part of any of the other BMW stereo units?
Old Tue, Mar-13-2018, 06:15:45 PM   #6
benzthis
benzthis's Avatar
Reputation: 0 benzthis is on a distinguished road
^^^op raise your aux line level!!it should sound good after the adjustment.
Jump to top benzthis is online now   Reply With Quote
Old Tue, Mar-13-2018, 06:21:01 PM   #7
oceansize
oceansize's Avatar
I don't have the Nav but my Harmon Kardon Business unit does have a aux line level adjustment. I just assumed the Nav would too. My bad if it doesn't.
On the non-nav, if I remember correctly you can access it by holding down the button with the note (i think). If you don't have an auxiliary input you will not get this option.
KW V2 Coilovers
Stoptech Brakes
MRR GT-1 Wheels
TTFS SMG Tune
Old Tue, Mar-13-2018, 09:27:50 PM   #8
elcidce91
Where would this aux volume level be in the Nav. version of the radio?
Old Wed, Mar-14-2018, 12:06:05 AM   #9
oceansize
oceansize's Avatar
According to this thread for the nav units you put your radio in auxiliary mode and then use the radio presets one through six to set the level. One being the lowest and six the highest.
KW V2 Coilovers
Stoptech Brakes
MRR GT-1 Wheels
TTFS SMG Tune
Old Wed, Mar-14-2018, 12:10:18 AM   #10
JamesSJ1
That's awesome. I'll report back in an hour or so if it works.
Edit: It works! Found that P3 was plenty to match my phone with the radio volume levels. You just press the radio preset buttons labeled 1-6, and in the top right corner of the screen you'll see P1 - P6 accordingly.
Discussing Aux Cable Volume Problems in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
