Old Tue, Mar-13-2018, 07:27:08 PM   #11
mrgizmo04
mrgizmo04's Avatar
Default Re: Rate my repair cost
Originally Posted by ctdriver86 View Post
I was just suggesting options. I know a reputable shop that charges around that amount to replace the smg pump with labor, and its about the same, if not a little more to do the manual swap (labor and bellhousing machining). But it also depends on your location. Some love the smg and want to stick with it, but it isn't much more to convert to manual if they would like. 3k is reasonable, even a good deal, assuming he has warranty on the smg pump. Again, only suggesting. =)
He never mentioned smg pump, that is why I was wondering why you took it down the conversion path...Unless you understood diff, clutch sleeve and smg switch to mean smg pump somehow. He got a used diff (which is probably the bulk of the cost), clutch slave cylinder and a gear position switch (per later confirmation in post 8).
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Tue, Mar-13-2018, 07:58:54 PM   #12
ctdriver86
Reputation: 0 ctdriver86 is on a distinguished road
Ah I stand corrected. I misread the first post.
Jump to top ctdriver86 is offline   Reply With Quote
Old Tue, Mar-13-2018, 08:03:52 PM   #13
mrgizmo04
mrgizmo04's Avatar
Ok cool. Got it
'05 M3 6MT coupe
Discussing Rate my repair cost in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
