Old Tue, Jan-31-2017, 01:55:45 AM   #31
m3 hal
Default Re: King Racing Bearings
Lang suggested King for the mains, I'll see if a rod bearing suggestion came up. He does have sort of a negative opinion on his site about WPC citing the tighter clearance after treatment.
source?
"We like to use BMW factory bearings with WPC treatment. WPC treatment has shown to increase rod bearing load bearing capacity and extend service life on all bearings so we choose to use it whenever possible."
http://www.langracing.com/bmw-e60-e6...ction-service/
Some test data by HKS/WPC from Lang's site: http://www.langracing.com/images/Bearing_Load.pdf
Old Tue, Jan-31-2017, 04:26:15 PM   #32
AndrewLang
Lang Racing Development
AndrewLang's Avatar
Reputation: 0 AndrewLang is on a distinguished road
There's no problem with S54 rod bearing clearance. It's about .0020". The King bearings are closer to .0030". I have an open box set I'll sell for 50$, they are too loose for me to use on anything.
Store | Facebook | Blog
Jump to top AndrewLang is offline   Reply With Quote
Old Tue, Jan-31-2017, 04:45:11 PM   #33
HassanEido
HassanEido's Avatar
Lebanon
Thanks for the info on clearance do u know if ACL ones are ok?
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
368.4 whp 289.1 wtq
Old Tue, Jan-31-2017, 04:47:17 PM   #34
AndrewLang
AndrewLang's Avatar
Originally Posted by Flow View Post
Aren't the mains color coded and you need to order the same color bearing as the marking on the crank ? Or how does this work ?
It seems to me like main bearing clearance varies more by the block than the crank. Any of the bearing kits you buy will have the same bearing size throughout. If you want to be that accurate you'll need to buy all the different colors.
Old Tue, Jan-31-2017, 04:57:36 PM   #35
AndrewLang
AndrewLang's Avatar
I haven't bought a set of those before.
Old Tue, Jan-31-2017, 05:38:51 PM   #36
.'s Avatar
Reputation: 0 . is on a distinguished road
Since we're on the topic of WPC and if it works, how does it compare to microblue treatment? Is there any reason to believe one process is better than the other for the purpose of rod bearings?
2001 E46 M3 - Slicktop Manual Coupe - Alpine White on Imola Red
Engine: Karbonius CSL airbox, Lang Racing stage 2.5 head, Schrick 288/280 cams & followers, Lang Racing rod journal widening kit w/ CP 12:1 87.5mm pistons & Carrillo rods, ARP head studs, Epic Motorsports tune, TMS Power Pulleys, ECS catch can, Supersprint V1 stepped headers & section 1, SGT scza section 3.
Drivetrain: Clutch Masters FX725, Clutch Masters Hydraulic TB, AKG stage II shifter, RE trans mounts, Motorsport 4.10 R&P, Revshift 80A diff bushings, mason clutch pedal.
Suspension/Brakes: Bilstein PSS9's, RE RSM's, UUC sway bars, PFC direct drive rotors, PFC 08's, Nitto NT05's, Motorsport Hardware 75mm stud kit.
Coming soon: Cobra Nogaro seats, Supersprint dual 2.5" section 2, RTD V2 mini shifter, BW Street/Track rear camber arms, Turner monoball RTAB's.
IG: Zach_e46M
Jump to top . is offline   Reply With Quote
Old Tue, Jan-31-2017, 05:56:19 PM   #37
Nicholas1996
Reputation: 0 Nicholas1996 is on a distinguished road
Greece
Are all king bearings too loose? Or just that particular set?
Also how much are you guys selling King Racing rod bearings?
Sent from my LG-H811 using Tapatalk
Topaz Blau
PTE 6266 on E85
AEM Infinity
Tuned by Ian @Bend Calibration
Jump to top Nicholas1996 is offline   Reply With Quote
Old Tue, Jan-31-2017, 07:06:40 PM   #38
Flow
Flow's Avatar
France
Exactly. I would stick with OE for the mains, are they are color coded and have different thicknesses, and not go with one-size-fits-all other brands. Thank you for your input.
2004 M3 TiAg / LSB SMG
Old Tue, Jan-31-2017, 08:26:19 PM   #39
AndrewLang
AndrewLang's Avatar
Not exactly what I meant. I use the King/ACL bearings quite frequently and I also sell them and advise that people use them, the cost savings is pretty significant.
Old Wed, Feb-01-2017, 09:09:10 PM   #40
digger
Originally Posted by m3 hal View Post
More bearing surface area is exposed due to the small dimples, resulting in an increased volume of oil on the bearing.
i can see more surface area but the added volume would be immeasurably small, the question is why would more surface area to volume do anything for a bearing film
there is no denying the process works on reduced friction with metal to metal contact with boundary or mixed lubrication so if you suffer loss of lubrication (including first start on cold engine among other scenarios such as detonation or starvation) then you will get less incremental damage giving longer life but i wonder if there is some evidence that there is a friction reduction with normal hydrodynamic lubrication when things are operating as normal to.
1996 e36 M3 Evo
Jump to top digger is offline   Reply With Quote
Discussing King Racing Bearings in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
