Old Sat, Feb-24-2018, 07:12:01 PM   #581
PHARMDVIPER
Reputation: 0 PHARMDVIPER is on a distinguished road
Originally Posted by mitesh33 View Post
Honestly donít waste your time with Gear Position Sensor, itís not needed, everything on mine works as it should without one, cruise control, which deactivates when you press the brake, press the clutch. No difference.
Is this true? I have a ZCP so no cruise control anyway....will it throw any dash lights not having it?
Jump to top PHARMDVIPER is offline   Reply With Quote
Old Sat, Feb-24-2018, 11:00:01 PM   #582
Being3
Being3's Avatar
Reputation: 0 Being3 is on a distinguished road
Default Comprehensive SMG to 6MT Conversion Thread
Originally Posted by cjcuprill View Post
I have a 2003 M3 SMG, which I love but I am looking to convert it from the SMG to Manual. Though I am a YouTube mechanic a DYI is way above my head for a car I rely on for a daily transport. So with that said I live in the DMV (VA) area and am looking for a shop or some BMW gearheads that can help me convert my baby. My plan is to buy the parts then, with your help, find a shop or person/s who can do the conversion for the cost of labor or several cases of beer your choice
If anyone knows of a shop or person that will to the conversion for the cost of labor if I supply the parts please PM or email me!
Thanks in advance
There is an easy way to do it ... u can just use a RTD shifter with no mods to trans. As it has the gear select spring built into shifter. U donít even have to remove the trans.
Jump to top Being3 is offline   Reply With Quote
Old Sat, Feb-24-2018, 11:33:36 PM   #583
You should probably at least retrofit the clutch sensor, but the gear sensor can be omitted. You'll have to do a minor DME edit to have such a setup.
It's worth doing even if you don't use cruise control, since the DME uses that information for a little more than cruise control.
Old Sat, Feb-24-2018, 11:38:56 PM   #584
PHARMDVIPER
that is my plan...do the clutch sensor but forget about the gear sensor
Old Tue, Feb-27-2018, 02:27:10 AM   #585
Blaikenstein
Blaikenstein's Avatar
Reputation: 0 Blaikenstein is on a distinguished road
Did you swap yours with just the RTD shifter? I read the thread on e46f but there were some conflicting posts towards the end about the gates not lining up correctly without the lockout shifter. Seems like a no brainer if itís a straight swap.
-BlAikenstein
Jump to top Blaikenstein is offline   Reply With Quote
Old Sat, Mar-10-2018, 01:05:17 PM   #586
PHARMDVIPER
Iím in the middle of doing my swap and I need help with the reverse lights....I am not doing a gear identification switch since it can be coded out...how will I have reverse lights?
Old Sat, Mar-10-2018, 06:48:08 PM   #587
ddaniel1
ddaniel1's Avatar
Reputation: 0 ddaniel1 is on a distinguished road
Backup light switch is below and to the right of where you would put the gear identification switch, both SMG and 6MT have this switch, your connector should plug right up. The pic in post 577 of the tap shows the reverse switch.
Jump to top ddaniel1 is offline   Reply With Quote
Old Sat, Mar-10-2018, 06:57:40 PM   #588
mrgizmo04
mrgizmo04's Avatar
The backup light/reverse switch is already in the tranny. What you tap in post 577 is the gear id switch on the smg tranny because originally it sits in the actuator in the back of the smg gearshift assembly, which you discard in the conversion.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Sat, Mar-10-2018, 08:05:21 PM   #589
PHARMDVIPER
Ok cool so like others have said if I donít want cruise control (zcp) then I donít even need it right?
Old Mon, Mar-12-2018, 05:56:44 PM   #590
PHARMDVIPER
Can someone clarify taking apart the ews connector to add the wire....working under the dash is a PITA
