Old Wed, Mar-14-2018, 05:51:59 AM   #1
Alex Sol
Alex Sol's Avatar
Reputation: 0 Alex Sol is on a distinguished road
Default Trailer Question - can I sue stock if i change the muffler?
I'm in need of a trailer hitch and like the westfalia solution and looking at the simplest... if it works.
Use the Curt unit for the e46 non m3 cars and get a simple exhaust set up. Lighter weight solutions from megan and bimmerworld look okay to me.
Will this work? Anyone with first hand experience?
1991 Guards Red Porsche 964 C2
2009 335d
2003 m3
Jump to top Alex Sol is offline   Reply With Quote
Old Wed, Mar-14-2018, 04:16:53 PM   #2
04yfz
Reputation: 0 04yfz is on a distinguished road
Default Re: Trailer Question - can I sue stock if i change the muffler?
I believe there was a member on here that did a westfalia install, I don't recall which exhaust he had but the end result was very clean. HE would remove the diffuser when installing the hitch and then reinstall it when the ball was removed (it's a J or U shape).
Pat
Jump to top 04yfz is offline   Reply With Quote
Old Thu, Mar-15-2018, 06:14:50 AM   #3
tmaxx445
Likes to Eat AMGs
tmaxx445's Avatar
Reputation: 0 tmaxx445 is on a distinguished road
This may be of interest if you haven't seen this thread yet:
http://www.m3forum.net/m3forum/showthread.php?t=349258
2005 M3 Coupe / 6 Speed / Silver Gray Metallic / Black Nappa Leather / Premium / Cold Weather / Bi Xenons / Adjustable Bolsters / Lumbar / MKIV Navigation / Harmon Kardon Hifi / Sirius / Aux In / Bluetooth / Rain Sensor / Home Link / BMW Assist / Alarm / Hard Wired Radar Detector / LED Interior Lights / Carbon Interior Trim / Alcantara Pillars / ZHP Shift Knob / Short Shifter / Custom Tune / StreamLine Intake / IAT Relocation / Dynamic Air Scoops / Fan Delete / SS Headers / AR20 Resonator / Electric Exhaust Bypass Valve / Koni Yellow Adjustables / Eibach Pro Kit Springs / PowerFlex & AKG Poly Bushings / M Track Mode / RedLine Fluids / PFC Z-Rated Street Pads / Staggered OEM CSLs / 275 & 245 595 Evos / 12mm Front Spacer / 10mm Rear Spacer / Orion V2 Angel Eyes / Carbon CSL Splitters / Matched Reflectors / SunTek Carbon 38% Tint
Jump to top tmaxx445 is offline   Reply With Quote
Old Thu, Mar-22-2018, 04:39:07 AM   #4
Alex Sol
Alex Sol's Avatar
Thanks for the response and I did see the westfalia solution. Clean install and seems a little expensive. I was thinking that I'd set up a single tail pipe while and run a stock e46 cheapie hitch. Just wondering if it is only the issue of the giant exhaust vs the non m3 exhausts that have the extra room.
2009 335d
2003 m3
Old Thu, Mar-22-2018, 05:31:50 AM   #5
lmtfi
lmtfi's Avatar
With the WF solution - make sure what you are pulling is small and light - like a small, lightweight tire trailer. That solution is not meant to pull anything more. Some feel it is a borderline for even that. I would inspect everything for cracks a few times each year.
I wouldn't recommend anything less than the WF design.
Old Thu, Mar-22-2018, 02:16:47 PM   #6
bmw m3 s50
Why So Serious ? :}
bmw m3 s50's Avatar
Reputation: 0 bmw m3 s50 is on a distinguished road
Portugal
Honestly you should probably buy a tire roof rack that carries tires over the trailer.
Best solution is buying an old cheap SUV/Pick up Truck with a cheap trailer to trailer your M3 and whatever else.
Jump to top bmw m3 s50 is offline   Reply With Quote
Old Fri, Mar-23-2018, 04:32:42 AM   #7
04yfz
The cheap E46 hitches mount to the spare tire well which the M3 does not have. I wouldn't want to hack up my cars body anyway, plus it seems very sketchy to have it mounted to sheet metal. I wouldn't do anything less than the westfalia.
Pat
Old Fri, Mar-23-2018, 11:24:36 AM   #8
I drove an M3 with 4 track tires on a roof rack once, and it was absolutely miserable. I didn't feel comfortable going over ~60 on the highway.
I disliked it almost as much as I disliked towing my car to the track. Super happy I'll never be doing that, again.
Best solution is 4 tires in the back seat, secured with the back seat seat belts
Discussing Trailer Question - can I sue stock if i change the muffler? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
