Old Sun, Mar-11-2018, 02:39:17 PM   #1
oceansize
Kwisatz Haderach
oceansize's Avatar
Reputation: 0 oceansize is on a distinguished road
Default DIY Redux (Plasti Dip): Refinished my Radio Bracket and Sunglass Holder, Again
Hey all,
My first post on this last weekend got a fair amount of views and some of you were good enough to make suggestions on what might look better. My trim was bad and honestly I'm not even sure how someone even goes about beating up trim like that. It was like they took a screw driver and stabbed it to death. Anyways, the gist of the suggestions was that I should use Plasti Dip or buy new trim. I don't want to buy new trim right now as I have more pressing concerns (my seats). I just want better looking trim. However, it is a rainy chilly weekend so I thought lets spend the $5.50 and give Plasti Dip a whirl. I followed the exact same procedures
Materials:
1. Black Plasti Dip
2. 180 Grit Sanpaper (I used 4 sheets)
3. 400 Grit Sandpaper (I used 2 sheets)
4. 0000 Steel Wool
5. Degreaser (I just used Rubbing Alcohol)
6. Tack Cloth
Steps
1. Remove Radio, Sunglass Holder, and Ashtray compartment. I used this. I removed the door from the radio bracket. You don't need to remove the sunglass holder door
2. Sand using 180 grit. This is a PITA and took quite a while.
3. After a good base smooth base has been established follow with the 400.
4. Then follow with the Steel Wool
5. Then use the degreaser of your choice (I used rubbing alcohol).
6. Use the tack cloth, gently, to remove any debris.
7. I applied 4 medium coats waiting 30 minutes between each coat.
8. Wait 4 hours to dry, reinstall.
Bottom line IMO: Plasti Dip wins.
1. Plasti Dip feels like OEM
2. Plasti Dip fills in dents and sanding faults better.
3. Duplicolor feels more durable.
4. I think I should have used more coats of the Duplicolor. If I had went 5 or 6 coats it would have likely turned out smoother.
If your trim is rough and you don't feel like spending the money on brackets then absolutely do this. You won't be disappointed.
2003 M3 Convertible SMG w/Hardtop
KW V2 Coilovers
ESS VT1-475 Gen 3 Supercharger
Stoptech Brakes
MRR GT-1 Wheels
TTFS SMG Tune
Rogue Eng. Diablo Exhaust w/ SS Tips
Rogue Eng. Rasp Pipe
Redish Reinforcement Plates
Polyurethane Rear Subframe Bushings
Polyurethane Differential Bushings
Beisan Oil Pump Disk
Jump to top oceansize is offline   Reply With Quote
Old Sun, Mar-11-2018, 02:42:55 PM   #2
AETBX
Reputation: 0 AETBX is on a distinguished road
Default Re: DIY Redux (Plasti Dip): Refinished my Radio Bracket and Sunglass Holder, Again
Looks great
Jump to top AETBX is offline   Reply With Quote
Old Sun, Mar-11-2018, 05:07:26 PM   #3
oceansize
Kwisatz Haderach
oceansize's Avatar
Originally Posted by ///Mclovinit View Post
Looks great
Thanks Mclovinit. The suggestions from the guys in the first thread I posted were spot on.
KW V2 Coilovers
Stoptech Brakes
MRR GT-1 Wheels
TTFS SMG Tune
Old Wed, Mar-14-2018, 12:46:20 AM   #4
Danwilz
Reputation: 0 Danwilz is on a distinguished road
Good job! I knew this would be 100x better!
Jump to top Danwilz is offline   Reply With Quote
Old Wed, Mar-14-2018, 01:26:10 AM   #5
J-ReaL
J-ReaL's Avatar
Reputation: 0 J-ReaL is on a distinguished road
Looks super clean man nice job, really unique look for the finish product gives a cool different accent.
2001 Carbonschwarzenegger Cabriolet 6M/T | 171K | Mishy Sexy Fan | Turner Pullzeyz | AFE Intekken | Turner/Fluidyne Core
Jump to top J-ReaL is offline   Reply With Quote
Old Wed, Mar-14-2018, 04:17:51 AM   #6
FK
Reputation: 0 FK is on a distinguished road
Brah why is it still upside down though lol
Jump to top FK is offline   Reply With Quote
Discussing DIY Redux (Plasti Dip): Refinished my Radio Bracket and Sunglass Holder, Again in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
