Old Thu, May-02-2019, 11:46:20 PM   #1
sapote
Default SMG Brushless motor
This 350 watts motor 80RBL03A costs $60 or less in quantity, with shaft OD=12mm, body OD=60mm, and length=100mm. It’s perfect to drive the pump. If someone want to commercial this product I can help to provide the driver circuit or you can buy the driver below for $45.
https://www.alibaba.com/product-deta...5294544bT1rWg6
Driver:
https://www.ebay.com/itm/BLD-300B-BL...4383.l4275.c10
Motor has 6 wires to be connected to the driver. This driver has motor motion control than you need for this ON/OFF application.
W,V,U are 3 phase wiring to be connected to driver. They supply the motor current.
HW, HV, HU (or A, B, C) are the 3 Hall sensor signals for brushless cummutation. They serve as the brushes/commutator in the brush motor. They tells the driver when to switch the W,V,U currents.
DC+ and DC- of the driver connected to 12V and GND. The driver should have a RUN signal input to command the driver when to run or stop the motor.
So total around $100 or less in quantity and will outlast the life of the car.
Might need to make the mounting flange for the existing motor mounting.
Old Thu, May-02-2019, 11:59:00 PM   #2
icecream
Registered Apples
icecream's Avatar
Default Re: SMG Brushless motor
What makes you think a cheap brushless motor from chinachinachina and cheap driver is going to last longer than the solutions we have now? Between the constant cycling, heat and vibration I doubt you'll see it last like the OEM one.
Old Fri, May-03-2019, 12:00:43 AM   #3
kokgo20
kokgo20's Avatar
The shaft needs to be machined to match the pump drive
Build thread---------- INSTAGRAM ------------ROTREX REBUILD-------------Now offering custom digital gauges
2004 SMG PY/BLK - 600 TCKline - CPI Headers & resonated Sec1- Stoptech BBK 6 pod front & 4 pod rear with steel lines - 75mm Studs conversion - SDW monoball RTABs - AKG subframe bushings - Multi color AEs - FR-X 3.0 Projectors - Smoked Side markers - Euro bumper - V1 with hard wire & Stealth one - M Track Mod - ZCP steering rack - Dual LI - CSL Style diffuser - SCZA Exhaust - E9x Door handle LED retrofit - SCZA CSL bootlid - VEI systems custom air vent A/F & boost gauge - VEI custom air vent Water temp & oil pressure guage- Active Prima plus + TTFS tune - Mishimoto Radiator & Oil cooler - H&R front Sway - UUC camber arms - keyless & push to start system - clear bra - interiors red stitching contrast - Apex PS7s - 16" Spal fan
Old Fri, May-03-2019, 12:01:58 AM   #4
kokgo20
kokgo20's Avatar
I believe because it's brushless, the brushes & commutator wear normally what kill this motor
Old Fri, May-03-2019, 12:03:04 AM   #5
Aeko
Aeko's Avatar
Reputation: 0 Aeko is on a distinguished road
At this point it's kind of a cheap R&D deal... if it winds up that we can find a more reliable long-term solution with more engineering, why not? The point here is sapote is trying to utilize a brushless motor that *might* have a better longevity in the types of conditions the SMG pump undergoes.
-edit-
Also this. Or do like SMG Society does and just grind the f*%$er so it fits.
If you wanna make REAL donuts, run Crisco in your diff.
Jump to top Aeko is offline   Reply With Quote
Old Fri, May-03-2019, 12:12:00 AM   #6
sapote
90% of all motors are now made in China, and all the electronic components inside your iphone or TV or cars. I don't think it's cheap = low quality. Motors are just copper wires and magnets and bearings.
The driver has FETs made by either STM, Infineon, or International Rectifier, On Semiconductor, NXP. They are not cheap Chinese chips but all were made in China, Thailand, Vietnam.
I designed motor/motion controller (as this ebay driver but custom designed to fit in smaller package like inside a movie camera) for a living, and I can tell this motor is a good quality based on its solid AL housing and machine finish. Cheap stuffs have sheet metal or pot metal housing. The drivers not cheap stuffs either but probably surplus goods from CNC controllers.
Old Fri, May-03-2019, 12:37:11 AM   #7
sapote
This is one of the motor that I designed -- electrical spec'd and mechanical. The beauty of the brushless is the rotor magnet and the field wiwing stator. This is in total opposite with a brush motor with magnet stator and coil wiring as rotor which cannot transfer the heat to the housing effectively. The motor I designed has only 3 wires and no Hall signals but using a microprocessor to read the motor encoder and commutate the 3 phase wires and control motor speed-- precise enough to sync the 24 frames per second pictures with the audio recorder.
So motors and controllers is not new to me.
A little more on this special motor: the stator coil wirings were potted in Epoxy to prevent any vibration of the copper coils. We bought the motor as frameless -- no housing no shaft no bearings but just the coil stator and the magnet rotor, then we designed the custom housing, shaft and bearings. It has to be very quiet to prevent motor noise recorded on the movie.
Old Fri, May-03-2019, 02:47:54 AM   #8
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
That's pretty Cool...
Old Fri, May-03-2019, 03:58:21 AM   #9
Blaikenstein
Blaikenstein's Avatar
Reputation: 0 Blaikenstein is on a distinguished road
Find an upgraded accumulator and make a frankenSMG!
I love seeing experiments play out
Jump to top Blaikenstein is offline   Reply With Quote
Old Fri, May-03-2019, 04:32:52 AM   #10
icecream
Registered Apples
icecream's Avatar
Yeah I get that but there are different levels of quality and I have no idea what r and d went into this brushless wonder and driver for 100 dollars. I just have my doubts is all. My oem one lasted 180k. Point was I dont know if going to alliboobi and ebay is the best choice for a critical component that is heavily used and abused. Maybe it is. Only one way to find out.
Discussing SMG Brushless motor in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
