Old Sun, Oct-14-2012, 11:51:42 PM   #1
aeronaut
aeronaut's Avatar
Reputation: 0 aeronaut is on a distinguished road
Exclamation Rubbin's Racin'...I'll be calling TCKline
Installed Koni 1200's from TCKline, with HR OE springs. That's the only changes to the rear axle from anything other than OEM. Seems somewhere in the upper half of suspension travel, my brake caliper is rubbing the shock body. This is an exact setup that TCKline sells. Not good. Not happy. Spacing washer may be all it needs to fix this. But.
EDIT: Update, wanted to make sure any casual viewer of this thread understands that there is NOTHING wrong with this TCKLine setup. It was my incorrect diagnosis of the (non) problem.
Jump to top aeronaut is offline   Reply With Quote
Old Mon, Oct-15-2012, 12:49:36 AM   #2
OahuMPower
:FACEPALM:
OahuMPower's Avatar
Default Re: Rubbin's Racin'...I'll be calling TCKline
thats not possible if everything is installed correctly
Old Mon, Oct-15-2012, 01:00:37 AM   #3
das borgen
Off-Topic King
das borgen's Avatar
Reputation: 0 das borgen is on a distinguished road
+1....
Jump to top das borgen is offline   Reply With Quote
Old Mon, Oct-15-2012, 01:34:09 AM   #4
aeronaut
aeronaut's Avatar
Happy to hear what could be wrong with the install. Triple checked location of washer from instructions. Bolt torqued. Using TCKline RSM's. Pretty much that simple. FYI, I believe the 1200's are larger diameter than the other Koni's.
Old Mon, Oct-15-2012, 03:35:08 AM   #5
hencini
Carlos is My Co-Pilot
hencini's Avatar
Weird. Shock is three bolts. Not rocket surgery. And it hardly seems possible that your caliper is in there wrong. Would it even be possible to put them on the wrong sides?
Is it happening on both sides?
Old Mon, Oct-15-2012, 05:54:58 AM   #6
MMMGP
retired
MMMGP's Avatar
Reputation: 0 MMMGP is on a distinguished road
Poland
Torn upper shock mounts? Could the brake line be loose--maybe there is a brake line retaining bracket missing? Could torn RTAB pockets allow enough movement for contact?
'18 Tesla Model 3 Dual Motor
'18 BMW i3S BEV
Jump to top MMMGP is offline   Reply With Quote
Old Mon, Oct-15-2012, 06:43:04 AM   #7
aeronaut
aeronaut's Avatar
New RSM's. RTAB pockets recently checked, new RTAB's. Both sides rubbing (left side less than right). To my knowledge, there is no left/right rear shock, they are identical. Unknown if it would be possibly to mount rear brake calipers on wrong sides. Hmmmm. That would have happened prior to my purchase of car. BUT, my right side looks identical the Nitram's picture, so they seem to be mounted correctly. I'll measure the distance between the caliper and the shock at full extension and report back. It doesn't appear that there's as much clearance as in Nitram's picture, but there is a few inches or clearance at full extension (see my second pic).
Is rear suspension geometry/parts different on a 95?
Edit: Just checked. The rear trailing arm for 95 is a different part number than other years.
Old Mon, Oct-15-2012, 07:15:19 AM   #8
Roland H
LOLiticks troll
Roland H's Avatar
Reputation: 0 Roland H is on a distinguished road
Something is wrong, they shouldn't even be close. trailing arm for a 95 is a different part number, but not much different physically.
Jump to top Roland H is offline   Reply With Quote
Old Mon, Oct-15-2012, 10:14:34 AM   #9
A White m3
///M POWER
A White m3's Avatar
Reputation: 0 A White m3 is on a distinguished road
take the spring out of the perch and use a floor jack to jack up the shock to its full travel and see whats going on. My guess would be the inner bushings on the control arms and or the ball joints(allowing excessive camber under hard cornering/accel), any other thing would have no effect on the spacing between the caliper and the shock as already mentioned.
S54 E36 M3 // E46 M3 6 // FELONY E36 M3
Jump to top A White m3 is offline   Reply With Quote
Old Mon, Oct-15-2012, 11:02:18 AM   #10
aeronaut
aeronaut's Avatar
Bushings and ball joints have been inspected twice in the past few months. Stock shocks did not rub. No odd tire wear showing up. But, I will do this today!
Discussing Rubbin's Racin'...I'll be calling TCKline in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
