Old Tue, Jul-24-2012, 10:32:58 PM   #1
brice017
Reputation: 0 brice017 is on a distinguished road
Default Gas vapors in cabin
Here's my problem. When I come to a stop, the cabin starts to fill with gasoline vapors.
I have removed the rear seat, looked at both the fuel pumps - no vapors, no leaks
I have no leaks underneath of the vehicle
I have no leaks under the hood
I do have a slight gasoline smell under the hood when idling
I do not have the smell when I am driving, only when stopped or stop/go traffic
Occurs whether the vehicle gas tank is topped off or on empty.
Where under the hood do the fuel lines run?
Any suggestions?
Jump to top brice017 is offline   Reply With Quote
Old Tue, Jul-24-2012, 10:55:45 PM   #2
enderw88
Rolling Restorer
enderw88's Avatar
Reputation: 0 enderw88 is on a distinguished road
Default Re: Gas vapors in cabin
OK, this is a big deal so no screwing around
E36 M3's have a fuel filter beneath the the car, just about directly below the drivers right leg in the transmission tunnel. I would check there for leaks as well. You are most likely to get leaks at fuel line junctions. That means pump output, fuel filter inlet and outlet and injector rail.
Gasoline is volatile, meaning it evaporates quickly. You will not see evidence of leaks unless everything is cold (like winter).
First pull the plastic engine covers off, and leave them off. You will be able to locate leaks around the injectors far easier.
Any suggestions?
Vapor from slow leaks will be diffused by airflow, so no surprise there. I would let the engine idle in a garage and start nose hunting around the injectors. Also get the car off the ground and inspect the fuel filter and fuel pump.
Craig, Tucson AZ
New Buyers Please Read
Originally Posted by JitteryJoe View Post
Buying the car is going to turn out the be the least expensive part of this experience. Fun though.
Jump to top enderw88 is offline   Reply With Quote
Old Tue, Jul-24-2012, 11:13:04 PM   #3
A White m3
///M POWER
A White m3's Avatar
Reputation: 0 A White m3 is on a distinguished road
what if you get a gas smell on wot pulls? this happens occasionally, my girlfriend usually comments on it, is this just due to the engine running a bit rich?
S54 E36 M3 // E46 M3 6 // FELONY E36 M3
Jump to top A White m3 is offline   Reply With Quote
Old Tue, Jul-24-2012, 11:19:54 PM   #4
idriveastick
Reputation: 0 idriveastick has disabled reputation
Or your girlfriend thinks she smells fuel but it's just exhaust or what I call "the e36 smell" since there's always some sort of smell going on with these older cars. That is, unless you're totally rebuilt etc.
Jump to top idriveastick is offline   Reply With Quote
Old Wed, Jul-25-2012, 12:21:10 AM   #5
brice017
thanks for the quick response. I will put it on ramps tomarrow and "sniff" around.
Old Thu, Jul-26-2012, 11:46:03 PM   #6
marvinstockman
Reputation: 0 marvinstockman is on a distinguished road
A gas leak is usually a cheap money fix at a good shop you might know, and save you and the car from burning up.
Jump to top marvinstockman is offline   Reply With Quote
Old Fri, Jul-27-2012, 11:48:45 AM   #7
brice017
Wanted to thank enderw88 for his assistance, and wanted to close out this thread // update it for any others who happen to come across this thread searching our forum with similar issues:
Fuel Filter - Fine, no smells
Fuel Injectors - Fine, could not see any "spray" when idling using a flood light
About 6 months ago, the car started making a "thud, thud" sound in the engine bay. This is different than the "tin can rattle" that I have going on which is my dead vanos (the car is a 96 with 265K, so I can't complain)
Sound was coming from passenger side of engine block, near the secondary air pump's control valve.
Turns out my spark plug (or plugs) were slightly loose, causing the "thud, thud" noise when the engine is doing its compression. (replaced spark plugs 4 yrs ago @ 200K)
No more "thud, thud" and no more gas vapors in cabin.
A google search of loose spark plug and gas vapor correlate this finding.
thanks guys
Old Fri, Jul-27-2012, 12:52:19 PM   #8
enderw88
Rolling Restorer
enderw88's Avatar
Nice to hear. Good catch on the spark plugs!
Craig, Tucson AZ
Old Thu, Aug-02-2012, 11:27:59 PM   #9
utahm3
Reputation: 0 utahm3 is on a distinguished road
Bosnia and Herzegovina
Hate to bring this thread back from the dead but I wanted to give my story of gas vapors in the cabin and outside of the car. Hopefully this can benefit future forum searchers with similar issues.
I'm pretty new to e36 M3s so this might be obvious info. I had a fuel smell in the cabin usually after filling up or after spirited driving. I never fill up more then half the tank in my cars unless I'm going on long trips.
Long story short after some research it ended up being the fuel sender. At first it wasn't easy to find as both the fuel sender and fuel pump looked dry, no wet spots. It only became visible after I filled the tank all the way full. Gas started to come up and drip all over my garage.
Jump to top utahm3 is offline   Reply With Quote
Discussing Gas vapors in cabin in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
