Old Wed, Apr-06-2011, 07:19:08 PM   #11
MalikSaab
Reputation: 0 MalikSaab is on a distinguished road
Default Re: MY keyless entry is not working in my 2003 m3 smg vert after rear view mirror ins
Okay I sent my mirror in to be rebuilt and i got it back today and it looks good. I plugged it in and hooked it up my keyless entry isnt working???? Is there something i need to do to make it work again. Btw I was using my 528i mirror for the time being until I got my oval one back let me know.
Jump to top MalikSaab is offline   Reply With Quote
Old Wed, Apr-06-2011, 07:59:54 PM   #12
MightyY
Reputation: 0 MightyY is on a distinguished road
Try reprogramming the key to the car? Just grasping at straws. Did you try your spare key?
Jump to top MightyY is offline   Reply With Quote
Old Wed, Apr-06-2011, 08:37:40 PM   #13
MalikSaab
How do i reprogram the key explain me all instructions what to do thanks
Old Wed, Apr-06-2011, 08:49:49 PM   #14
MightyY
http://www.bimmerfest.com/forums/att...0&d=1231280426
Old Wed, Apr-06-2011, 08:58:18 PM   #15
MalikSaab
Ill check that out tonight. But when you put the key in you turn it to position one and go from there and turn it to off and while key is in ignition you press arrow and roundel 3x's and itll go from there is that correct
Old Thu, Apr-07-2011, 08:00:03 PM   #16
MalikSaab
It works now !!!
Discussing MY keyless entry is not working in my 2003 m3 smg vert after rear view mirror install in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
