Old Wed, Oct-08-2014, 10:20:29 PM   #1
m3new
Reputation: 0 m3new is on a distinguished road
Default Mapping for Burble & Pops..
Does anyone know the location or the map name for the overrun fuel cut tables??
Ahem..Terra....SliM3..
KL_SWE_SW_DIFF??
Jump to top m3new is offline   Reply With Quote
Old Thu, Oct-09-2014, 10:49:19 AM   #2
SchLanD
Reputation: 0 SchLanD is on a distinguished road
Germany
Default Re: Mapping for Burble & Pops..
check the _SA_ maps SA=Schubabschaltung -> overrun
overrun is meaning turning off all injectors when you go off the throttle
I can translate some things for you:
K_SA_MD_HYS dynamic torque threshold for activation overrun
K_SA_MSR_SPERRZEIT disable overrun for x after some DSC things happend
K_SA_TKAT cat temperature threshold, before is no overrun possible
K_SA_WDK throttle threshold when injection will be turned off immediatly
KF_SA_TIME_TMOT_N40 delay for overrun triggering
There are 3 steps,
1. recognizing you to activate overrun
2. overrun-readiness (delay), and use a minimum of spark and fuel
3. activate overrun, by shutting down injection
K_TZ_SA_CONTROL configures if there should be spark retard for overrun 1 => active and 0 => inactive
but there will be still the torque manager which will control ignition
These are just some basic infos, i have to read more to understand it completely. But maybe this will help you.
Jump to top SchLanD is offline   Reply With Quote
Old Thu, Oct-09-2014, 12:12:46 PM   #3
M3CARBON1
Reputation: 0 M3CARBON1 is on a distinguished road
United Kingdom
Thanks for this, but surely this method is overly complicated? I thought It should be as simple as changing the overrun areas in the base fuel map which are lean back to rich (as the pops come from un-burnt fuel in the exhaust) my understanding is NOT to cut fuel on overrun at all. As you wont get any pops that way..............
As I know it...dump fuel in all cylinders in overrun and advance ignition timing...In the same area's of both maps....
Jump to top M3CARBON1 is offline   Reply With Quote
Old Thu, Oct-09-2014, 01:01:20 PM   #4
JuicyM3
Popopopop
Reputation: 0 JuicyM3 is on a distinguished road
Evolve can tune it in for you Be aware that it's very loud and violent.
Nothing like modern burble/overrun you find on F-type/M235i etc
Jump to top JuicyM3 is offline   Reply With Quote
Old Thu, Oct-09-2014, 01:31:42 PM   #5
zirrah
fack
zirrah's Avatar
Reputation: 0 zirrah is on a distinguished road
Yup. Image PSE for a Porsche, only magnified x5.
"Oh god no, not the clutch. "Das wha ma knee is fo. Is fo cluchin". "
2006 CB Comp Pack and everything else
Jump to top zirrah is offline   Reply With Quote
Old Thu, Oct-09-2014, 01:36:06 PM   #6
cossie1
Reputation: 0 cossie1 is on a distinguished road
United Kingdom
Why advance the timing ?
When we used to do this in the Evo's we would retard the ignition to get the pops and bangs.
Jump to top cossie1 is offline   Reply With Quote
Old Thu, Oct-09-2014, 01:49:37 PM   #7
m3new
Retarding will give you a bang rather than a pop and crackle, burble...
Old Thu, Oct-09-2014, 02:02:59 PM   #8
SliM3
SliM3's Avatar
Sorry, I don't know much about initiating this condition, but I'd take a guess that the reason why it's so violent is because this mod interferes with engine drag torque control (MSR). Not good if you visit the track every once in a while.
///M3 '06 Carbon Black
-Benjamin Franklin
- Fuel adaptations explained
- Checksum Verification
Old Thu, Oct-09-2014, 02:10:42 PM   #9
SchLanD
Germany
But there is a misunderstanding, overrun areas are not lean in base fuel map, they are very rich, at least it does not matter because, injection is turned off instantly when you go off the throttle.
Easy way to make it burple is just to set K_SA_TKAT (default 10) to 1000, then injectors won't cut off. Try it, nothing should happen but a way higher fuel consumption.
Old Fri, Oct-10-2014, 12:09:02 AM   #10
m3new
I dont think so, the over run parts of the fuel map (top right) shows higher figures of 1.30...This is a LEAN figure..not rich...taking numbers away from this map adds fuel.....The same places in the base ignition map are way advanced...60 degrees...It makes sense....If not explain why?
If we can activate burble with K_SA_TKAT then why the need for all the other K_SA maps?
Discussing Mapping for Burble & Pops.. in the Coding and Tuning Forum - Discuss all avenues of coding and tuning here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
