Old Mon, Mar-16-2009, 08:03:43 PM   #1
tonggi
Tonggi Tuning, LLC
tonggi's Avatar
Reputation: 0 tonggi is on a distinguished road
Default Rear Ball Joint Replacement DIY?
Anyone have a DIY for how to replace the rear ball joints?
I want to replace all 4 since 1 is broken. Figured I can do all 4 due to the cheap price of the parts.
it is this part:
I don't know which tool/extractor. puller to use.
Possibly this one?
http://www.harborfreight.com/cpi/cta...emnumber=38335
Or this one?
http://www.harborfreight.com/cpi/cta...temnumber=8856
If anyone has an idea of what tool to use or have done it. PLease let me know
I heard that Victory use to make one but not anymore. I would really like to know the exact tool to use. Thanks!
Also when i do. I will create a DIY thread for this install. T hanks!!!!!!!!!!!!!
TiTS Racing in association with MMFN Racing and AYO STFU
2001 AW Tonggi mobile (RIP)
2000 nonya.
Jump to top tonggi is offline   Reply With Quote
Old Mon, Mar-16-2009, 08:14:43 PM   #2
tonggi
Tonggi Tuning, LLC
tonggi's Avatar
THis DIY is pretty simple. I created a tool similiar to BMWs tool with HUGE sockets.
all 1/2 size sockets
1 1/4 (puller)
16 (installer)
32 (catcher)
threaded rod (3/16)
washers
nuts
Create the tool (self explanatory)
TOols:
18 mm socket
18 mm wrench
ratchet
music
PB BLASTER
First you must do tons of prep work.
Jack up car
Remove wheels
remove pads and depress piston
remove piston
remove screws (7 mm allen IIRC)
remove the rotor.
Now everything is set. Remove the rear control arm bolt (18mm) on both sides
Now the bushing is nice and present.
Now put the tool on the bushing like so:
The bushing will then Push it out with the smaller socket. Will be a pain at first as lining up the sockets will need perfection. Once its out of the arm the tool will come off complete and hide the ball joint as shown:
Now clean up the arm to get rid of any grease or any debris:
Now prepare the installer socket to PUSH the new balljoint into place (better than hammering that b*tch in) like shown:
Admire the new bushing installed:
and
Now same goes for the top. 18mm on both sides then add the tool:
same process to install new one as well:
BAM you just replaced your bushings with minimal effort. I hope this was helpful to you. If your local to the tristate area and would liek this done PM me details. Also please leave feedback. Thanks!
DIY FOUND HERE:
http://www.m3forum.net/m3forum/showthread.php?t=308090
2000 nonya.
Old Mon, Mar-16-2009, 08:15:09 PM   #3
m3 hal
I heard one is easy and the other is a pain, I forget which is which though. I think one of them has an access issue, probably the top one.
Jump to top m3 hal is online now   Reply With Quote
Old Mon, Mar-16-2009, 08:26:20 PM   #4
tonggi
Tonggi Tuning, LLC
tonggi's Avatar
I agree.
I might just tackle 2 for now. But I want to make sure I am going to use the right tools. Or possibly a technique someone can share.
2000 nonya.
Old Mon, Mar-16-2009, 08:29:36 PM   #5
SG_M3
#56 JP M3
Reputation: 0 SG_M3 has disabled reputation
I've done it on my e36, same process as the e46. Use the bmw tool, it makes it a 15 min per bushing job. Otherwise its a PITA.
Sean
- 98 M3 EB/BLK
Jump to top SG_M3 is offline   Reply With Quote
Old Mon, Mar-16-2009, 08:37:42 PM   #6
tonggi
Tonggi Tuning, LLC
tonggi's Avatar
Thanks for the input. I saw on BFC they are the same. Which BMW tool are you referring to? Please point me to the right one so I can order it as soon as I can. Thanks.
It's not this is it?
http://cgi.ebay.com/ebaymotors/BMW-R...motiveQ5fTools
2000 nonya.
Old Mon, Mar-16-2009, 08:40:31 PM   #7
tonggi
Tonggi Tuning, LLC
tonggi's Avatar
or this tool?
http://www.harborfreight.com/cpi/cta...emnumber=46389
and with this:
Im trying to avoid buying that $260 tool kit.
2000 nonya.
Old Mon, Mar-16-2009, 08:54:44 PM   #8
SG_M3
#56 JP M3
B334191, it looks very similar to that. Like the rtab tool, but with cups to press in/out that fit the ball joint size.
You could probably build something using threaded rod, some washers, the right size sockets. I tried the 2nd tool from harbor freight, didn't work.
Sean
- 98 M3 EB/BLK
Old Tue, Mar-17-2009, 01:40:34 AM   #9
mmmpowr
mmmpowr's Avatar
Reputation: 0 mmmpowr is on a distinguished road
Originally Posted by tonggi View Post
Part B333351
Piece a cake with this tool. Friends shop has this tool and was helping them out on a customers car. Replaced all 4 of the bushings in less than an hour.
David
2001 ///M3
OEM: 6-Speed | Titanium Silver Metallic | Imola Nappa Leather | Power Seat Package | Cold Weather Package | Width adj. front seat with lumbar | Xenon | Moonroof | In-dash CD | HK | BMW alarm | Univeral transceiver
Mods: OEM Strut brace | OEM 19" wheels (street) | RAC RS110 9.5"(f)/10"(r) wheels (track) | Brembo 355(f)/345(r) BBK | Motul RBF600brake fluid | ACS rear shock tower brace | D/A Race software | SS Stepped Headers/S-pipe/X-pipe w/resonator/Race muffler | RE pullies | aFe CAI stg1 | Bimmerworld intake elbow | Bimmerworld CF brake ducts | BMW Motorsport thermostat | TCK D/A coilovers w/#600(f)/#700(r) | GC camber/castor Race plate | Powerflex FCAB | GC front sway bar links | h-Sport sway bars | RE Tranny mounts | TCK RTAB | GC RLCA| TCK shock mounts | V-CSL CF trunk | V-CSL CF diffuser | McMahan 4pt rollbar | TMS oil cooler | RE Octane SSK
Jump to top mmmpowr is offline   Reply With Quote
Old Tue, Mar-17-2009, 02:01:01 PM   #10
tonggi
Tonggi Tuning, LLC
tonggi's Avatar
so it is inevitable. I will have to fork the cash for that toolkit?
I wonder if there is a way i can make my own tool. : (
the tool it is $260.
2000 nonya.
ball, diy, joint, rear, replacement
ball joint question? dallasloungeguy E46 M3 (2001-2006) 9 Sat, Nov-10-2007 12:24:46 AM
Need rear ball joint tool dukes Mid Atlantic 8 Wed, May-23-2007 04:04:36 PM
ball joint spudski67 E36 M3 (1992-1999) 8 Wed, Feb-21-2007 05:19:58 PM
Ball Joint Replacement Angella E36 M3 (1992-1999) 8 Mon, Feb-07-2005 05:16:38 PM
lower ball joint replacement ? Kerplunk E36 M3 (1992-1999) 6 Tue, Oct-19-2004 02:29:17 PM
Discussing Rear Ball Joint Replacement DIY? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
