Old Mon, Jul-22-2019, 12:56:54 PM   #691
Olza
Code monkey
Olza's Avatar
Reputation: 0 Olza is on a distinguished road
Belarus
Default Re: Comprehensive MSS50 DME information (Euro E36 M3 S50B32 321 PS)
Originally Posted by VincentM3E36 View Post
Ok I will try to do some test soon.
I also try to calculate one of the input of the alpha N map (maybe aq_rel or tps I don't know). I've found this formula in the code :
aq_rel[k] = (((FFF71E[k] * FFC710[k])/512 (K_46304 + 3) * 4) * 87/64)/4
but I haven't found yet what are FFF71E and FFC710...
FFF71E - raw TPS AD data. FFC710 not sure, some kind of heat extension factor from engine temp .C_TPS_MAX_IS_byte_46304 - max idle throttle potentiometer adaptation threshold.
Jump to top Olza is offline   Reply With Quote
Old Fri, Jul-26-2019, 09:38:48 PM   #692
VincentM3E36
Reputation: 0 VincentM3E36 is on a distinguished road
France
Do you know on how many bits the potentiometer voltage (0-5V) is acquired by the dme ? Maybe 10 bits (0->1023 raw data) ?
Jump to top VincentM3E36 is offline   Reply With Quote
Old Fri, Jul-26-2019, 11:37:44 PM   #693
MSS54 is 10-bit, I imagine imagine MSS50 is similar in that regard.
Old Sat, Jul-27-2019, 03:40:02 PM   #694
VincentM3E36
France
It is consistent with potentiometer voltage in the DIS which varies every approximately 5mV
Old Sat, Jul-27-2019, 06:03:51 PM   #695
VincentM3E36
France
I ploted the input of the alpha map when analogic TPS voltage varies from 0 to 5V acquired on 10 bits thanks to the formula I found in the program. I keep stock value of C_TPS_MAX_IS = 46 and no heating compensation : FFC710 = 512 (pic 1). It is very consistent with the input of the alpha N map when you let the input in raw data (pic 2). The only strange things is this C_TPS_MAX_IS value because the input of the map starts to become different from 0 only when TPS voltage is upper 1V. It is not possible to have load signal equal to 0ms under 1V (when maf is removed).
My maf is removed and DIS shows load values between 1 and 2ms under TPS = 1V
Old Fri, Aug-09-2019, 04:51:19 PM   #696
VincentM3E36
France
I am going to answer my own question : the right formula is :
aq_rel[k] = (((FFF71E[k] * FFC710[k])/512 – FFC692[k]/64) * 87/64)/4
where FFC692 must be the current idle throttle potentiometer adaptation and C_TPS_MAX_IS is the max idle throttle potentiometer adaptation that the DME allows.
So I think the idle throttle potentiometer adaptation can vary in the range 0-1V. My plot above corresponds to the maximum of the idle throttle potentiometer adaptation.
Old Tue, Sep-10-2019, 02:10:31 AM   #697
dafoxm3
Reputation: 0 dafoxm3 is on a distinguished road
Hi All, just closing some posts and an update.
After much tinkering and looking for the problems with the LTFT - it appears that after all it was a faulty TPS! voltage from .6 through to 1.1 were reading incorrectly so part throttle was running super rich under medium load. with a new TPS LTFT values came back to about +1.2%
this still has not explained the high fuel consumption though (which is still present)
I also went down the path of a new Alpha-N tune that was provided to me by a very patient and awesome member on this forum. the tune is great and car feels very strong in the mid range now.
i may do some "back yard" tuning on Vanos and ignition but am still a little cautious on how far i can move the Vanos cam values. . .
So in short , LTFT values are sorted!
however car is still using lots of fuel in the city - consumption is about 390km to a full 60L on the highway i can get 580-600kM to 60L
Now moving on to my question. . .
Does anyone have any ideas or suggestions on how to get DTM style exhaust flames on decell.???
i was thinking of just adding more fuel in the 05 and 08 range on part throttle map in the high rpm and also retarding timing slightly ? would this get the flames or would i blow something up ?? haha
Jump to top dafoxm3 is offline   Reply With Quote
Old Thu, Sep-19-2019, 08:50:59 AM   #698
Lambda1
Reputation: 0 Lambda1 is on a distinguished road
To get this flames you need three things:
1. Fuel when throttle nearly closed,
2. retard Ign. in specific area under specific conditions (mostly -16 up to -23 degress works well),
3. more air in this condition (can be done via icv).
(4. decat, better straight exhaust and hot enough engine).
Its nearly all time the same way for pop and bang, flames...
Problem often are rev hanging... can be adjust by other values for deceleration tables.
But why would you do this to a great engine like S50 be...
Jump to top Lambda1 is offline   Reply With Quote
Old Mon, Nov-04-2019, 03:55:06 AM   #699
dafoxm3
Hi Lambda1, thanks for the info!
Main reason is, I do like the flames when im on the track flat out. . like a DTM cars.
Does anyone know the decel maps for fuel and ignition ?
also i am searching for the hex addresses for Knock values ?
Old Wed, Nov-06-2019, 09:45:53 PM   #700
Thomsvaslar
Reputation: 0 Thomsvaslar is on a distinguished road
Hi guys! I am from Greece and have a bmw e36 m3 321hp,i will want too much a Xdf for Remap my car. I use it only for drift and hillclimb race. My email is thomasvas@hotmail.gr
Jump to top Thomsvaslar is offline   Reply With Quote
Discussing Comprehensive MSS50 DME information (Euro E36 M3 S50B32 321 PS) in the Coding and Tuning Forum - Discuss all avenues of coding and tuning here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
