Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > BMW M3 Discussions > M3 Frequently Asked Questions > E36 FAQ
Old Mon, Mar-28-2005, 04:29:47 PM   #11
Sirius
How many licks..
Sirius's Avatar
Reputation: 45 Sirius has disabled reputation
I left the other hidden functions out of my writeup because they are mainly used for diagnostic purposus.
But if you're intrested, heres how to fully unlock the obc and access it completely:
http://home.att.net/~ebaines/e36_obc.htm
♪♫♪♪♫♪ Trevor ♪♫♪♪♫♪
97' M3. '10 R6.
Jump to top Sirius is offline   Reply With Quote
Old Mon, Mar-28-2005, 07:59:08 PM   #12
Sirius
How many licks..
Sirius's Avatar
Off to faq.
97' M3. '10 R6.
Old Tue, Oct-30-2007, 09:21:16 AM   #13
Turismo
Reputation: 0 Turismo is on a distinguished road
This forum is fantastic, I didn't even know I had a BC button, it certainly makes retrieving information from the OBD much more ergonomic.
Jump to top Turismo is offline   Reply With Quote
Old Thu, Feb-14-2008, 04:04:51 AM   #14
hencini
Carlos is My Co-Pilot
hencini's Avatar
Reputation: 0 hencini is a jewel in the rough
Originally Posted by Sirius View Post
Let’s start with the 1/10/100/1000 buttons. Thoes are used to set numbers according to their decimal position.
Example: When setting the time, you have this format: 12:34. To change the 1, you use the 1 button, to change the 2 you use the 10 button, to change the 3 you use the 100 button and to change the 4 you use the 1000 button.
Isn't this backwards? The 1 should change the 4, the 10 should change the 3, the 100 should change the 2, the 1000 should change the 1, right?
Or it could be that I'm over tired and shouldn't be awake, much less throwing my around...
75 years and 350,000 miles of fun:
1998 M3/4/5 No mods, just maintenance
1983 CJ-7 No maintenance, just mods
1983 R65LS No intention of modding it, don't know how to maintain it
Jump to top hencini is offline   Reply With Quote
Old Wed, Jun-25-2008, 06:38:19 AM   #15
workerrobot
Reputation: 0 workerrobot is on a distinguished road
oh man, those links to the hidden function pages are down...does anyone have that info saved that they could post in this thread? thanks.
Jump to top workerrobot is offline   Reply With Quote
Old Thu, Apr-16-2009, 05:43:10 AM   #16
whistla
Reputation: 0 whistla is on a distinguished road
+1 please.
Jump to top whistla is offline   Reply With Quote
Old Sat, Oct-16-2010, 03:39:54 AM   #17
////\/\3
Reputation: 0 ////\/\3 is on a distinguished road
I found this:
http://www.bimmerinfo.com/E36_OBC_tricks.htm
in here:
http://www.m3forum.net/m3forum/showthread.php?t=269846
Jump to top ////\/\3 is offline   Reply With Quote
Old Tue, Nov-22-2011, 03:57:24 PM   #18
Lowe187
Reputation: 0 Lowe187 is on a distinguished road
Germany
Default Re: Confused - OBC Buttons and Settings
I've tried setting my clock several times I can put the time in but then it's stuck with "input time" if I press anything else it zeros out the time how to I set it up rite
Sorry I know it's probably something simple but I'm new to BMW
Jump to top Lowe187 is offline   Reply With Quote
Old Thu, Nov-14-2013, 01:47:34 AM   #19
Edscuba
Reputation: 0 Edscuba is on a distinguished road
How about when check control comes on to tell you low washer fluid and it's full or tail light failure and they are OK? Is there a reset for these? I keep getting these codes and they do not exist.
Jump to top Edscuba is offline   Reply With Quote
Old Thu, Nov-14-2013, 03:03:29 AM   #20
hencini
hencini's Avatar
The system is actually pretty smart. You probably need to replace your washer fluid level sensor. And if you're running aftermarket taillights, the fake tail light failure is common. If you have Depos, there is a fix that involves clipping a splice in them or something. Search around.
buttons, confused, obc, settings
how to convert 11 button obc to 18 button obc NCUTRONE M3Forum Welcome Center 1 Fri, Aug-24-2007 06:15:19 AM
Car Memory settings and Key Memory settings versace7866 E46 M3 (2001-2006) 32 Mon, Jun-11-2007 06:05:50 PM
The buttons...sooo many buttons cstang68 E36 M3 (1992-1999) 2 Fri, Sep-16-2005 03:42:29 AM
Difference between 18 button OBC and 11 button OBC? iNcUbUs_21 E36 M3 (1992-1999) 15 Tue, Jun-08-2004 08:43:37 PM
Why four buttons? slkj23oj E46 M3 (2001-2006) 10 Mon, Mar-29-2004 06:53:50 AM
Discussing Confused - OBC Buttons and Settings in the E36 FAQ Forum - at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
