E46 M3 (2001-2006) Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm Total Produced: 45,000+ - Years Produced: 2001 to 2006. |
#1011 |
You mean studs not bolts and I would get N54 studs like bigo says if you're going to replace them.
If you're going to reuse your stock studs, get some nuts without a shoulder (not like the header nuts) that are M7x1.00 to do the double nut method. Though, there may just be room enough to use the stock header nuts even with their shoulder, I would just get some thin ones to be sure.
/// 2004 SilberGrau M3 · Coupe · 6MT · slicktop · zero options · ~3100lbs · JOURNAL ![]() Evolve-R Alpha N · Evolve CF CSL Airbox · Eventuri Scoop · Supersprint V1 stepped 2.5" · SS V1 2.5" sect 1· SS unres 2.5" sect 2 · SCZA 2.5" sect 3 · Besian · RE pulleys/fan delete · CSL battery Bilstein HD B6 + GroundControl/Eibach 325/550lb + GC "tall" RSMs · Hotchkis front sway · F & R strut bars · TMS camber & subframe plates · Eibach alu rear camber arms · RE trans mounts · AKG poly subf/diff 95a · SDW RTAB · OE weighted ///M knob + ZHP alcantara boot + UUC DSSR OE CSL trunk · Cobra Nogaros + BK + manual OE bases · TMS black pedals · Sportline 8S 18"x 8.5/9.5" · MPSS 245/275 · APEX 75mm Studs · Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL · ZHP "712" rack |
Sponsored Links |
#1012 |
Remind me again. Loctite or no Loctite on the header studs? If Loctite, blue or red?
#1013 |
#1014 | |
![]() Quote:
Blue is probably best for the studs themselves, copper (maybe nickel?) anti-seize for the nuts. |
#1015 |
Expansive and expensive. I don't really watch Fox, or any TV really. The governments are socialist but not the markets. Either way I'm here to discuss M3 related things. I just want to know because it potentially affects his ability to buy M3 things. He answered and we can move on.
'06 Alpine White III - Cinnamon Interior Buildjournal Tune | CSL Trans Software | Megan Racing Headers | Turner Power Pulleys | GruppeM Ti muffler | K&N Filter | ECS Silicone Intake Boot | SMG(Conversion coming one day) | Stainless Steel Vanos line | Dinan Strut Reinforcement bars F&R | OEM Sec 1 and 2 Exhaust | OEM Intake | Pioneer Radio | CSL Trunk | Headliner that isn't Saggy | Poorly Wrapped Steering Wheel by Previous Owner ![]() ![]() |
#1016 |
How common is the issue with walking studs though? I used new studs and nuts with no issue. I also torqued them down a bit more than specs because getting a torque wrench in there seems impossible.
#1017 |
![]() Location: Long Beach
ok ok....so i must admit, ive been stuck in the same damn place for the past two or three weeks (working only 1 or 2 nights per week) trying to get the nuts onto the old studs for the rear section/rear set of headers. no matter what i simply cannot get the nuts to 'start' on the threads. its so frustrating. ive taken them back out...cleaned the threads, hand threaded them on w/o the headers in place (barely goes on) but once i put the headers on...no go!
its so frustrating. who else has had this problem? what was your solve? honestly, im about 5 mins away from putting all the parts in the trunk and having the car towed to a shop and let them finish the install as im out of patience... I’m using brand new OEM copper nuts + brand new OEM gaskets btw.. ![]() ![]() ![]() Last edited by umichchris; Thu, Mar-28-2019 at 05:23:37 AM. |
#1018 | |
![]() Quote:
'85 528e 164k miles (sold) '05 M3 6MT coupe All DIY: VANOS, WPC rod bearings, full SS (SS stepped V1 headers, catted S1, stock S2, SS sport), AFD E85 Proflex kit, Ohlins R&T/Hyperco 375f Swift 672r/GC street tops and camber plates, ST40 355 pfc08, 330 ZHP steering rack, diffsonline 4.1 diff with rem polish, E60 short shifter lever, AKG black diff bushings/subframe bushings, Rogue rtab, Sachs clutch/flywheel, rear main, Beyer driveshaft, valve adjustment, cooling refresh. Happy to help with VANOS or any other DIY job around NorCal. Have various specialty tools (VANOS, RTAB, engine bar, valve adjustment, tranny jack, ball joint separator, pilot bearing puller, tap&die kit, etc). |
#1019 | |
![]() Quote:
#1020 | |
its the 3 or 4 of them that are the most difficult to get straight-on pressure to. so when im turning...its just spinning on top of the stud and im wasting my life away while awkwardly hanging over the car.
definitely ready to tow it to a shop - though, seeing some of the replies in this lengthy thread, doing the N54 studs might help me if they are in fact longer, id have a better chance of getting the nuts to 'start' on the threads. not sure how hard it would be to remove the old OEM studs though Quote:
Bookmarks |
Thread Tools | |
Display Modes | |
