Old Tue, Jun-26-2018, 03:31:42 AM   #11
Ace280
Reputation: 0 Ace280 is on a distinguished road
Default Re: 1st to 2nd gear super notchy at full throttle...Thoughts?
I had a problem with going from first to second and I changed to Redline D4 ATF and it is night and day difference.
SGT Coilovers, Turner Motorsports Sway Bars, Mason Engineering Rear Strut Brace, Front Strut Brace, Hotchkis Rear End Links, RE Short Shifter, The Orginal Vince Bar
Power Mods - RE Pullies, Fan delete, TTFS Tune, Euro Header, Euro Cats, B-Line Intake, Borla Muffler, AFD E85 kit, 3.91 diff
Jump to top Ace280 is offline   Reply With Quote
Old Tue, Jun-26-2018, 07:10:34 AM   #12
Hamann_m3
Reputation: 0 Hamann_m3 is on a distinguished road
What was the night and day difference ? Smooth shifts? can you please elaborate...Thanks man
Jump to top Hamann_m3 is offline   Reply With Quote
Old Thu, Jun-28-2018, 01:52:14 PM   #13
JerseyDriver820
Reputation: 0 JerseyDriver820 is on a distinguished road
If it were me, I would remove the CDV first. Simple job and makes a huge difference on engagement and speed of the clutch. It may solve your issues like it did for me. Then I would do fluid.
Jump to top JerseyDriver820 is offline   Reply With Quote
Old Thu, Jun-28-2018, 02:19:22 PM   #14
Texaz3
Definitely CDV delete and fluid first.
Old Thu, Jun-28-2018, 02:43:18 PM   #15
BTB
BTB's Avatar
Trans/motor mounts?
My Journal
Jump to top BTB is online now   Reply With Quote
Old Thu, Jun-28-2018, 02:57:37 PM   #16
mrgizmo04
mrgizmo04's Avatar
How will removing clutch delay valve solve what op stated as his problem, which is fighting the stick while shifting gears and not being able to get it into gear? It is a 1-way restrictor, so disengaging the clutch is not impacted (fighting the stick to get it into gear happens with clutch disengaged), while engaging the clutch is where cdv comes into play and slows down the clutch engagement speed to take off stress off the drivetrain.
OP didn't say that his clutch engagement feels like it is too slow even if he dumps the clutch or feels like maybe clutch is worn or slipping and he is trying to figure out how to get it to engage quicker.
I might be misunderstanding the recommendation though?
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Thu, Jun-28-2018, 03:23:22 PM   #17
johndoe
S54 Addict!
Reputation: 0 johndoe is on a distinguished road
Namibia
maybe while you in there replace engine mounts and gearbox mounts if it hasn't already been done. then New oil and CDV delete, that should be a worthwhile service and from there you can look at other options if needed.
Jump to top johndoe is offline   Reply With Quote
Old Thu, Jun-28-2018, 04:26:09 PM   #18
neopolymath
neopolymath's Avatar
Reputation: 0 neopolymath is on a distinguished road
One method to create a differential diagnosis for this problem is to recreate the issue and then immediately turn the car off and attempt to shift into the problem gears. This can help determine if the problem is hydraulics related. Things like the cdv (although more likely a ballooning old clutch line) can cause the car to have these issues when warm only and while the car is running only.
Jump to top neopolymath is online now   Reply With Quote
Old Thu, Jun-28-2018, 08:11:27 PM   #19
M3Dom
M3Dom's Avatar
Reputation: 0 M3Dom is on a distinguished road
gizbo should be done
https://www.instagram.com/d_sicily/
Porshapwr:I thought every day was steak and BJ day?
Ghost : "She'll prolly suck your balls so hard they'll hatch"
Ben Z.;The Ultimate Driving Simulation Machine
LALaw :OP has been surprised by everything that's happened since the 13th Amendment
Cars : some verts some bikes and a 2012 veyron
Jump to top M3Dom is offline   Reply With Quote
Old Fri, Jun-29-2018, 01:52:01 AM   #20
Ace280
Much smoother shift after not being able to go from 1st to 2nd most of the time when I was shifting fast. I had already done the CDV delete, new clutch line, new motor mounts, new transmission mount, new clutch and pressure plate. I did not do all the other work because of the shifting problems, but because they needed it.
Discussing 1st to 2nd gear super notchy at full throttle...Thoughts? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
