Old Fri, Jan-10-2020, 08:59:12 PM   #1
haas16
Reputation: 0 haas16 is on a distinguished road
Default likely blown head gasket?
Sorry if this is the wrong forum for this type of post!
Car developed or more likely got a more noticeable version of an abnormal noise. happens low in the revs on partial throttle. Here are two videos that try to show the sound. one at idle from the bay and the other from the cabin with load as well.
Researching shows me this is a likely head gasket issue. I have not noticed any smoke on start. Have not noticed any oil or coolant leaks. When I checked the dipstick oil seemed to be its normal color. This sound does occur in neutral but not right away; car has to be driven or revved for it to begin. I checked INPA for the first time and did not see any related codes.
My main questions are:
Is my diagnosis of a blown head gasket likely? Can I drive this car to have a compression/leak-down test done or should it be towed? Since this is happening in neutral is there likely to be severe wear on the head or even block? What is the best way to tell if there is cylinder or piston damage?
Thank you all, I hope this all made sense and I'm not sounding crazy
Jump to top haas16 is offline   Reply With Quote
Old Fri, Jan-10-2020, 09:06:07 PM   #2
Drewster
Drewster's Avatar
Default Re: likely blown head gasket?
I would tow it to a shop - sounds like you might have a rod knocking on heaven's door..
Old Fri, Jan-10-2020, 09:11:55 PM   #3
haas16
oof not the news I wanted. what a day for my avin head unit to arrive
Old Fri, Jan-10-2020, 09:13:28 PM   #4
OEMaddict
Unregistered User
OEMaddict's Avatar
Reputation: 0 OEMaddict is on a distinguished road
I think you'd more likely hear pinging under load while in gear if you had a bad head gasket, other than the usual blue smoke on hard acceleration and oil in coolant. While a compression/leakdown test would be beneficial, I agree with Drewster that it sounds closer to rod knock...
Jump to top OEMaddict is offline   Reply With Quote
Old Fri, Jan-10-2020, 09:28:04 PM   #5
haas16
With the rod knock suggestions I wish i had a different title. Doing some quick reading people seem to debate rod knock sounds and vanos rattle. Can that be differentiated in this video or is there something else I could do?
Regardless with my whiff of a diagnosis towing to a shop to get a professional opinion is a must.
thanks again
Old Fri, Jan-10-2020, 09:30:20 PM   #6
icecream
Registered Apples
icecream's Avatar
thanks again
Pop the filter and cut it open. If a rod os knocking, you will likely have metal in there.
Old Fri, Jan-10-2020, 10:01:33 PM   #7
haas16
Ok will do that within an hour or two and report back.
Have a new filter to replace it with for when I was gonna do my oil change and oil analysis soon
Old Fri, Jan-10-2020, 11:01:03 PM   #8
02_LSB
Knock. Knock. Who’s there.
A rod.
Sorry OP. I hope I’m wrong.
LSB/Black | 6MT.
Brembo, TC Kline Double Adjustable, Full Supersprint, Beisan, Rod bearings, FX400 Single Mass Kit, AC Schnitzer, RACP plates + Bar + Too much Polyurethane.
SGM/Black E61 | 6MT
Stock
Jump to top 02_LSB is online now   Reply With Quote
Old Fri, Jan-10-2020, 11:30:29 PM   #9
haas16
https://imgur.com/a/UKlfa9Z
Heres the filter with a good look inside the folds. filled with gold glitter basically
Old Fri, Jan-10-2020, 11:34:15 PM   #10
haas16
Originally Posted by 02_LSB View Post
Knock. Knock. Whos there.
A rod.
Sorry OP. I hope Im wrong.
lol that got me. real gutted if it is a rod. Sad part is I have a blackstone oil kit and a fresh set of oil since i was going to check on this soon. Was only waiting on some parts from ecs tuning to realign front bumper cover at the same time which arrive Monday. Life can be cruel sometimes
Discussing likely blown head gasket? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
