Old Sat, Jan-04-2020, 03:58:43 PM   #1
mattaken
mattaken's Avatar
Reputation: 0 mattaken is on a distinguished road
Default Sound insulation
I have removed the old sound insulation from the engine bay and trans tunnels. I am asking for any recommendations for an easy to apply after market substitute.
Jump to top mattaken is offline   Reply With Quote
Old Sat, Jan-04-2020, 04:23:59 PM   #2
Drewster
Drewster's Avatar
Default Re: Sound insulation
DEI gold tape, they also have a floor and tunnel shield product
Old Sat, Jan-04-2020, 04:39:21 PM   #3
DirtyEtzio
DirtyEtzio's Avatar
Reputation: 0 DirtyEtzio is on a distinguished road
What are you trying to accomplish? Sound deadening, or simply blocking heat?
Sent from my SM-G955U using Tapatalk
  • Fully Race-Car'd and then wrecked. Starting over. Sigh.
Jump to top DirtyEtzio is offline   Reply With Quote
Old Sat, Jan-04-2020, 04:51:09 PM   #4
mattaken
mattaken's Avatar
Removed the stock sound/heat deadening material as it was worn and falling apart. Instead of buying expensive replacement pieces through the dealer Iím looking for other recommendations. This is a more track oriented vehicle and not much street driven.
Old Sat, Jan-04-2020, 05:04:57 PM   #5
Maybe some sort of spray would be easy to apply? As nd maybe not weight as much as butyl or other material? IDK
Old Sat, Jan-04-2020, 08:25:19 PM   #6
eacmen
i don't think the aluminum piece between exhaust and drive shaft is for sound deadoning. it's primary purpose is a heat shield.
[RIP] 2001 E46 M3, Tilton Triple Disc Clutch, JRZ RS2 (750/650), ST-40 332mm front BBK, BW TA16 Square 18x9.5, RE-71R 265/35R19, Redish Motorsport Plates, Mason X-Brace, Mason Front Strut Bar, RaceCapture Pro MK3 w/custom Raspberry Pi Dash.
Jump to top eacmen is offline   Reply With Quote
Old Sat, Jan-04-2020, 08:34:46 PM   #7
DirtyEtzio
DirtyEtzio's Avatar
Ok, I assume you're talking about the sort of "fabric" that's attached under the trans tunnel. Try looking into various forms of Dynomat or similar. They have different formulations for sound, heat, etc.
Old Sat, Jan-04-2020, 09:45:27 PM   #8
mattaken
mattaken's Avatar
Cool. Thx
Old Sun, Jan-05-2020, 01:10:31 AM   #9
bigjae1976
The problem with dynomat is I donít think itís designed for the amount of heat that it will be exposed to in that area. And the OEM material is likely fireproof (it has fiberglass short strands in it.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Sun, Jan-05-2020, 02:57:51 AM   #10
mattaken
mattaken's Avatar
Thatís good to know. Thank you
Discussing Sound insulation in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
