Old Fri, Dec-27-2019, 08:44:56 PM   #1
dutchhome
Reputation: 0 dutchhome is on a distinguished road
Default Quick, cheap, and easy VANOS oil pressure gauge
After installing my new cams I tested the VANOS. It was a bit slow to respond and Hassan thought the pressure might be a little low. The easiest is to pay $250 for a commercial solution. The cheapest was to drill and tap a vanos bolt and use a mixture of adapters to add a gauge to it.
I decided to look for an easier, cheaper solution and found one.
https://rover.ebay.com/rover/0/0/0?m...2F361110675174
This banjo bolt and this gauge go right together and fit perfectly. The bolt has fewer side holes and I was lucky enough that one pointed directly down the line to the accumulator.
All in it is just over $40. The worst part is waiting a week and a half for the bolt to arrive from the UK.
Sent from my Pixel 3 using Tapatalk
Jump to top dutchhome is offline   Reply With Quote
Old Fri, Dec-27-2019, 09:09:58 PM   #2
0-60Motorsports
Established 1998....
0-60Motorsports's Avatar
Bahrain
Default Re: Quick, cheap, and easy VANOS oil pressure gauge
Thatís great, thanks for the link
Old Fri, Dec-27-2019, 09:22:06 PM   #3
oceansize
Kwisatz Haderach
oceansize's Avatar
Excellent. Bought it and the bolt. Appreciate the link.
2003 M3 Convertible SMG w/Hardtop | GC Coilovers and Camber Plates | ESS VT1-475 Gen 3 Supercharger | Stoptech Brakes
Apex ARC-8 19" Hypersilver | CSL SMG (and 255) Tune | RE Diablo Exhaust w/ SS Tips | RE Rasp Pipe | SMG Relocation
Storm Motorwerks SMG Paddles | Two Tone Black/Grey Interior | Alcantara E-brake Boot
Very Recent Maintenance: FCABs | FCAs | RTABs | Motor Mounts | PS Hoses | Inner/Outer Tie Rods | End Links | Vanos Solenoid |
Driveshaft R&R | Flex Disc | Fan Clutch | Trans Fluid | Diff fluid
Old Fri, Dec-27-2019, 11:23:17 PM   #4
kokgo20
kokgo20's Avatar
Good find, I did the same thing but used the bolt from an old SMG GPS
Build thread---------- INSTAGRAM ------------ROTREX REBUILD-------------Now offering custom digital gauges
2004 SMG PY/BLK - 600 TCKline - CPI Headers & resonated Sec1- Stoptech BBK 6 pod front & 4 pod rear with steel lines - 75mm Studs conversion - SDW monoball RTABs - AKG subframe bushings - Multi color AEs - FR-X 3.0 Projectors - Smoked Side markers - Euro bumper - V1 with hard wire & Stealth one - M Track Mod - ZCP steering rack - Dual LI - CSL Style diffuser - SCZA Exhaust - E9x Door handle LED retrofit - SCZA CSL bootlid - VEI systems custom air vent A/F & boost gauge - VEI custom air vent Water temp & oil pressure guage- Active Prima plus + HTE performance tune - Custome fab intercooler - Mishimoto Radiator & Oil cooler - H&R front Sway - UUC camber arms - keyless & push to start system - clear bra - interiors red stitching contrast - Apex PS7s - 16" Spal fan
Old Sat, Dec-28-2019, 04:24:45 PM   #5
Jk715
Reputation: 0 Jk715 is on a distinguished road
What’s a healthy pressure for the vanos? Idle and at specific rpms.
Jump to top Jk715 is offline   Reply With Quote
Old Sat, Dec-28-2019, 04:32:58 PM   #6
115 bar
Old Sat, Dec-28-2019, 11:54:28 PM   #7
bimmerfan08
bimmerfan08's Avatar
FYI, here's a gauge that reads both PSI and bar.
"Valley Instrument Grade A Stem Mount 2 1/2in. Glycerin Filled Gauge — 0-3,000 PSI"
https://www.northerntool.com/shop/to..._357906_357906
Edit: looks like a 1/4" NPT female to 1/8" NPT male adapter will be needed to work with the banjo bolt in the OP
"The most difficult part of figuring out a car, the engineering, has been accomplished. Repairs and maintenance are simply dissembling parts and reassembling them." - bimmerfan08
Old Sat, Dec-28-2019, 11:56:37 PM   #8
dutchhome
Note that is not the right size to fit this bolt directly.
Old Sat, Dec-28-2019, 11:58:52 PM   #9
Are there any digital sensors that can fit there? Would be interesting to log the pressure while driving.
Old Sun, Dec-29-2019, 12:14:33 AM   #10
dutchhome
They seem to exist. This is the first one I turned up after a quick Google search but it seems fairly expensive and would still need to be connected to something to record the pressures.
https://discoveryparts.com/aim-data-...m-prs-839.html
Discussing Quick, cheap, and easy VANOS oil pressure gauge in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
