Old Thu, Dec-19-2019, 07:23:24 PM   #1
sapote
Default VANOS adaptation question
Is it true the vanos adaptation can take care for vanos timing setting error up to +/- 8 deg? If yes then how does the adaptation deal with this case: with IN piston touching the cap and the cam is set at 57 deg retarded instead of the correct 60 deg? To get the cam to 60 deg retarded the piston needs to move forward further but it is already hits the cap.
Jump to top sapote is online now   Reply With Quote
Old Thu, Dec-19-2019, 08:12:57 PM   #2
paulclaude
paulclaude's Avatar
Reputation: 0 paulclaude is on a distinguished road
Scotland
Default Re: VANOS adaptation question
Yes, it is true - did you did not believe me the first time?
The vanos adaptation simply allows an ECU offset for mechanical timing error. It doesn't physically move the camshaft, so being hard against the end caps will make no difference. Due to mechanical tolerances and imperfect installation work, it's difficult to time the camshafts perfectly every time. So the adaptation values are there to correct for this difference.
On a standalone ecu for comparison, camshaft synchronization would be carried out manually based on the cam sensor readings. On MSS54, adaptations are present to adjust for any difference.
2005 E46 M3 #Ringtool - Self Tuned - SSV2/2.5" SS Sect2/SS LWR - Schrick 288/280 - AEM Infinity - Karbonius CSL Intake - Nitron NTR R3 - Turner ARBs - Poly Bushed - Apex ARC-8 Square Setup - Alcon 365/345mm F&R BBK - Recaro SPGs - Sabelt Harnesses - SD MSA Full Cage - 6MT Conv. w/CAE Ultra Shifter - Seibon CSL Carbon Boot - MK-Rennsport GTS Wing - GSR Carbon Wings
Jump to top paulclaude is offline   Reply With Quote
Old Thu, Dec-19-2019, 09:09:47 PM   #3
Drewster
Drewster's Avatar
If you mechanically bottom out, it just doesn't go to 60 degrees.. but it's also not going to -3 degrees just because it can. It's why you see cars that are slightly mis-timed without any DTC's - even 3 degress off it still "passes" the Vanos test because it's within what the DME can just adapt to.
Old Thu, Dec-19-2019, 11:16:38 PM   #4
Are you confident the full range of travel is 60 degrees? Very well could be that it has extra travel to allow for such adaptions.
Of course if that's true, that means those who are careful enough to perfectly time their engines could perhaps increase the allowable vanos limits to get even more tuning capability.
Old Fri, Dec-20-2019, 03:08:15 AM   #5
sapote
No, I think the full mechanical travel is more than 60 deg, but if it's true then how does the DME protect valves from bending if the cam sensor gone wild, or the solenoid stuck open?
One day I will measure the piston travel range or the spline shaft range.
From this data below, could someone help explaining what are these data and their relationship: actual value; pilot control; adaptation.
actual value = 60
pilot control = 52.5
adaptation = -6.8
Did the DME controlled to 52.5 but the cam only got to 60? What prevented the vanos from moving the piston rearward to advance from 60 to 52.5?
Old Fri, Dec-20-2019, 03:13:46 AM   #6
Drewster
Drewster's Avatar
actual value = 60
adaptation = -6.8
Yes - the DME is requesting 52.5, but the current value is 60. The DME has adapted -6.8 degrees to correct the mechanical timing.
You should run the actual vanos test - it's a much better indication of the system.
Old Fri, Dec-20-2019, 04:20:29 AM   #7
There’s something weird with the 52.5° ones. A lot of software variants do that even when timed properly.
Old Fri, Dec-20-2019, 08:21:24 PM   #8
sapote
why the adaptation value is not 52.8 - 60 = - 7.2 but instead -6.8?
or, the adaptation value is a long term averaged offset to be used in addition to the permanent offset (as -2 for M3 and +3 for CSL until the code changed). In order words, the adaptation value of -6.8 is added to the wheel sensor reading data (relative to crank sensor) in the equation during the car operation period until the system come up with a new value.
Discussing VANOS adaptation question in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
