Old Mon, Dec-16-2019, 09:40:54 PM   #1
lemoose
lemoose's Avatar
Reputation: 0 lemoose is on a distinguished road
Default slight pull to the left under acceleration
to start things off, yes, my alignment has been done and the "issue" persists. I think what I'm noticing may be inherent to the design of the LSD in our cars, but I'd like to confirm. Under moderately hard acceleration (DSC off), I can feel the car pull to the left as rear tires are at their limit of traction. With the traction control on however, I can feel the car brake one of the rear wheels and keep the car straight.
anyone else notice anything similar?
Jump to top lemoose is offline   Reply With Quote
Old Mon, Dec-16-2019, 09:49:52 PM   #2
heinzboehmer
heinzboehmer's Avatar
Reputation: 0 heinzboehmer is on a distinguished road
Default Re: slight pull to the left under acceleration
How are all your rear bushings? Especially RTAB. Also how old is your suspension?
Jump to top heinzboehmer is online now   Reply With Quote
Old Mon, Dec-16-2019, 09:51:20 PM   #3
rovert604
rovert604's Avatar
This only happens if I hoon in the snow. Whenever I throttle enough to break traction the vehicle wants to point itself into oncoming. The ///M just loves to make you feel alive with puckering thrills. lol.
But if itís dry or wet, I donít really feel it unless I fully launch and get tires spinning. Then the right side will first push as the vehicle pivots then the left side hooks up once the LSD fully locks up.
--Trevor in 604--
Vancouver, BC, Canada
Old Mon, Dec-16-2019, 10:09:22 PM   #4
liam821
Reputation: 0 liam821 is on a distinguished road
This. I'd look at this first.
e46 M3 Phoenix Yellow
e46 M3 ZCP Interlagos Blue on Imola Red in many many many pieces...
e93 M3 Melbourne Red on Black Novillo leather
e70 xDrive35d Platinum Gray Metallic
Jump to top liam821 is online now   Reply With Quote
Old Mon, Dec-16-2019, 10:10:18 PM   #5
RTABs would be my first guess. Also seen this happen when one of the rear tires had a bad cord.
Old Tue, Dec-17-2019, 02:03:16 AM   #6
lemoose
lemoose's Avatar
This is exactly what im feeling. I feel like the diff is sending more power to the right side or the left tire is slipping, then i feel the diff lock up and distribute the power evenly. Almost as if it takes the diff a split second to ďsenseĒ slip and lock.
I got my RTABs (and all rear end busgings) done less than two years ago and tires have less than 2k miles on them
Old Tue, Dec-17-2019, 02:32:09 AM   #7
JohnVu
Reputation: 0 JohnVu is on a distinguished road
How are the rear camber arms? Mine were flexing really bad making the alignment almost impossible. I switched out to some SPC ones and the movement went away. However, I did do the subframe and diff bushings while swapping those.
Jump to top JohnVu is offline   Reply With Quote
Old Tue, Dec-17-2019, 02:51:55 AM   #8
Drewster
Drewster's Avatar
Either your RTABs are shot again, or someone cheated your alignment
Old Tue, Dec-17-2019, 02:54:55 AM   #9
rovert604
rovert604's Avatar
Yeah something is up with OPís car. Traction control does not have to intervene when I come away from any stop, hard and WOT. Mine is more of a playful nudge that is very easy to control.
--Trevor in 604--
Old Tue, Dec-17-2019, 03:07:14 AM   #10
lemoose
lemoose's Avatar
Its completely controllable it hardly nudges me half lane if i dont counter it. I did get my alignment looked at a second time but they even gave me the printout from the hunter machine showing everything within tolerance. Not ruling anything out, but i would find it rather unlikely.
Discussing slight pull to the left under acceleration in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
