Old Fri, Dec-13-2019, 08:37:04 PM   #1
F1Dryvr
Reputation: 0 F1Dryvr is on a distinguished road
Default Subframe...
For track only. Short of full subframe integrated cage.
Whats everyone done/planning to do for subframes. Plates are done on mine and i check routinely for new cracks and so far no evidence of any. Id like to get it more secure this winter and definitely doing the foam. Also considering the cmp bars. Not the racebrace.
I searched the track forum and its not really discussed.
Jump to top F1Dryvr is offline   Reply With Quote
Old Fri, Dec-13-2019, 08:55:07 PM   #2
eacmen
Default Re: Subframe...
You’re going to get varying opinions. Personally I did plates with the Mason X Brace and felt that was enough.
[RIP] 2001 E46 M3, Tilton Triple Disc Clutch, JRZ RS2 (750/650), ST-40 332mm front BBK, BW TA16 Square 18x9.5, RE-71R 265/35R19, Redish Motorsport Plates, Mason X-Brace, Mason Front Strut Bar, RaceCapture Pro MK3 w/custom Raspberry Pi Dash.
Jump to top eacmen is offline   Reply With Quote
Old Fri, Dec-13-2019, 09:20:15 PM   #3
F1Dryvr
I figured but thats what i wanted. Too see how many people went further than plates and how much further.
Old Fri, Dec-13-2019, 09:46:05 PM   #4
That's probably enough for weekend street car, but for a racecar, I'd want to, if not a cage, have some custom 6 point scaffolding or bracing done to connect 4 subframe mount pounts and shock towers. Plates if there are existing cracks, othereise I'd skip and do all "topside" work. Not ideal to lower the subframe, though CMP has special solid bushes to correct it.
/// 2004 SilberGrau M3 · Coupe · 6MT · slicktop · zero options · ~3100lbs · JOURNAL
Evolve-R Alpha N · Evolve CF CSL Airbox · Eventuri Scoop · Supersprint V1 stepped 2.5" · SS V1 2.5" sect 1 · OE sect 2 · SCZA 2.5" sect 3 · Besian · RE pulleys/fan delete · CSL battery
Bilstein HD B6 + GroundControl/Eibach 325/550lb + GC "tall" RSMs · Hotchkis front sway · F & R strut bars · TMS camber & subframe plates · Eibach alu rear camber arms · RE trans mounts · AKG poly subf/diff 95a · SDW RTAB · OE weighted ///M knob + ZHP alcantara boot + UUC DSSR
OE CSL trunk · Cobra Nogaros + BK + manual OE bases · TMS black pedals · Sportline 8S 18"x 8.5/9.5" · MPSS 245/275 · APEX 75mm Studs · Brembo 996 4 pot 345mm CSL + Textar & 328mm CSL + ATE · ZHP "712" rack
DD: 2012 TiAg/Blk 128i · N52 · ULEV · Slicktop · 6MT · manual heated seats
Eibach springs & sways · Koni STR.T · Whiteline SF bushes · Dinan camber plates · M3 FCAs
Old Fri, Dec-13-2019, 10:04:08 PM   #5
JerseyDriver820
Reputation: 0 JerseyDriver820 is on a distinguished road
I went for the full CMP solution during a group buy. It's overkill for a weekend track car but as the car continues to age, I'm sure I won't be disappointed that I chose an over engineered solution.
Do it right once, and move on. That's the theory at least lol
Sent from my Pixel XL using Tapatalk
Jump to top JerseyDriver820 is offline   Reply With Quote
Old Fri, Dec-13-2019, 10:56:46 PM   #6
SQ13
Probably the Vince bar bc it doesn't stick out like the CMP bar.
Old Sat, Dec-14-2019, 03:31:49 AM   #7
lmtfi
lmtfi's Avatar
I had plates done. My shop found a hairline on an RTAB pocket - so those got done as well.
Old Sat, Dec-14-2019, 05:15:16 AM   #8
eacmen
Was there a specific product you used to reinforce the RTAB pocket? Or did your shop just fab something up?
Old Sat, Dec-14-2019, 01:04:44 PM   #9
JerseyDriver820
Gargastic has a product, most people just reweld the seams I think
Old Sat, Dec-14-2019, 03:19:28 PM   #10
Drewster
Drewster's Avatar
Plates and foam - been fine for over 5 years now
Discussing Subframe... in the M3 Track: Racing and DE Forum - Best mod for speed is learning to get the most out of what you currently have. Tracks and DE's is the place to start! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
