Old Mon, Dec-09-2019, 12:47:30 AM   #1
Pbj24
Pbj24's Avatar
Reputation: 0 Pbj24 is on a distinguished road
Default For those running the APE e85 kit, what’s the max recommended ethanol blend you’ve gotten?
Mine seems to stay between e20-e30. It looks like most people who run this kit get between e40-e60.
I recently got the injectors cleaned and a new AEM e85 fuel pump. Fuel filter and regulator are also new.
Any idea why my blend recommendation seems low?
Jump to top Pbj24 is offline   Reply With Quote
Old Mon, Dec-09-2019, 06:02:36 AM   #2
Jimbo's M
Reputation: 0 Jimbo's M is on a distinguished road
Default Re: For those running the APE e85 kit, what’s the max recommended ethanol blend you’v
For a realistic E85 comparison (say 103 octane and 80% ethanol), E28 will "only" raise your octane to ~94, certainly better than the 91 you normally see. I have the AFD kit and run ~E60 which is ~100 octane and have done so for almost a year with zero fuel pump or injector issues. All I can say is that the DME and compression ratio of the S54 make lovely work outta 100 octane fuel.
http://www.georgebelton.com/E85Calculator.php
Jump to top Jimbo's M is offline   Reply With Quote
Old Mon, Dec-09-2019, 01:01:17 PM   #3
.'s Avatar
Reputation: 0 . is on a distinguished road
Mine shows E100 for recommended
2001 E46 M3 - Slicktop Manual Coupe - Alpine White on Imola Red
Engine: Karbonius CSL airbox, Lang Racing stage 2.5 head, Schrick 288/280 cams & followers, Lang Racing rod journal widening kit w/ CP 12:1 87.5mm pistons & Carrillo rods, Kassel CSL DME & MAP conversion, 36lb injectors, Hassan tuned, APE Flex fuel kit, TMS Power Pulleys, SS V1 stepped headers & catless section 1, SS 2.5” twin-piped resonated section 2, SGT scza section 3.
Drivetrain: DKM Stage 2 Clutch, E60 Shifter, RE trans mounts, Motorsport 4.10 R&P, Revshift 80A diff bushings.
Suspension/Brakes: Ohlins 3DM “track day” kit, RE strut bar, AKG RSM's, UUC front sway bar, BW camber arms, TMS monoball RTABs, ZCP rotors, BW solid caliper guide bushings, PFC 08's, Motorsport Hardware stud kit.
Interior: Cobra Nogaro seats, alcantara headliner, BMW Performance pedals, OE alcantara boots, mason clutch pedal, Xtrons 9" headunit w/ carplay
IG: Zach_e46M
Jump to top . is offline   Reply With Quote
Old Mon, Dec-09-2019, 02:56:06 PM   #4
Pbj24
Pbj24's Avatar
I believe they all show e100 until you do a redline pull. Unless you’re running bigger injectors, it’s not recommended that you run 100% ethanol as the stock injectors can not support it.
Old Mon, Dec-09-2019, 03:00:14 PM   #5
Pbj24
Pbj24's Avatar
Nvm I see you got bigger injectors lol. I guess I should have also added ‘if you’re running stock injectors’ to the question
Old Mon, Dec-09-2019, 03:11:12 PM   #6
Drewster
Drewster's Avatar
You've got too much injector duty cycle
Old Mon, Dec-09-2019, 03:17:09 PM   #7
Pbj24
Pbj24's Avatar
Well I figured. I guess I just thought I should be at a lower duty cycle. Or maybe the app bugging.
After I got the injectors cleaned, I thought maybe it would go up but actually it went slightly down (recommended blend). I thought this was weird considering one injectors was flowing at around half capacity before cleaning
Old Mon, Dec-09-2019, 04:20:32 PM   #8
HassanEido
HassanEido's Avatar
Lebanon
Try resetting your fuel adaptations. Chances are your dme adapted to ur old fuel pump /filter combo.
Sent from my JKM-LX1 using Tapatalk
PM for performance tune requests
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Old Mon, Dec-09-2019, 04:35:43 PM   #9
Gary Powers
Taking the long way home.
Gary Powers's Avatar
Reputation: 0 Gary Powers is on a distinguished road
Just saw your insta post that you are almost at 400whp. Incredible.
'03 E46 M3
Jump to top Gary Powers is offline   Reply With Quote
Old Mon, Dec-09-2019, 04:48:59 PM   #10
.'s Avatar
Should be there when I make a run on full E85. Unfortunately I showed up with too much gas in the tank and limited how strong I could make the blend and only showed E50 at the time of the run and had dropped down to E46 by the time I was done as it was mixing in the tank.
IG: Zach_e46M
Discussing For those running the APE e85 kit, what’s the max recommended ethanol blend you’ve gotten? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
