Old Tue, Dec-03-2019, 08:36:54 PM   #1
sapote
Default What are these covers for?
Part #9 in this diagram: https://www.realoem.com/bmw/enUS/sho...diagId=51_3278
Both front wheel arches have the little covers where the brake cooling ducts exit. The left and the right covers are different parts with the left cover has a small opening while the right cover is solid. Why the need to cover up the brake cooling ducts?
Old Tue, Dec-03-2019, 08:54:12 PM   #2
Default Re: What are these covers for?
Warmer brakes in cold climates?
Old Tue, Dec-03-2019, 09:05:51 PM   #3
IDK why they come with the car stock, but I need a pair of the solid ones if anyone wants to sell me a set!
I threw mine out 15 years ago to use the stock brake cooling, but now that I have real forced in brake ducting I'd rather clean up the airflow in my fenders!
Old Tue, Dec-03-2019, 11:35:34 PM   #4
sapote
I don't know if brake needs to be warm, but maybe the covers are installed in winter to prevent mud filled ducts by the wheels.
Old Tue, Dec-03-2019, 11:39:56 PM   #5
Duct tape?
Old Tue, Dec-03-2019, 11:43:55 PM   #6
I mean warm up faster for better/faster operation for those in cold climates...
It's just a guess. We may never know. I removed mine 10 years ago and haven't thought about them since.
Old Tue, Dec-03-2019, 11:53:25 PM   #7
antknee
Reputation: 0 antknee is on a distinguished road
This was the first thing i removed when i got my car. Can’t believe how expensive that part is
www.instagram.com/snwmble
#snwmble
Current:
'05 BMW M3 - Silver Grey/Imola Red
'90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
Past:
'88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
'01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
'90 BMW 325i - Schwarz/Tan sport *Sold*
'89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
Jump to top antknee is offline   Reply With Quote
Old Wed, Dec-04-2019, 12:02:33 AM   #8
Sandeep1212
Sandeep1212's Avatar
Reputation: 0 Sandeep1212 is on a distinguished road
Ill check when I get home, but I actually may have two full sets. So if you need one of the right side (I'm sure it works on both sides)fully blocked off ones I may have one I can send you.
2003.5 TIAG Black 6MT Gone
2003.5 Carbon Black Laguna Seca Blue SMG Current
Supersprint V1/Supersprint straight pipe sec 1/ Supersprint X-pipe/OEM Muffler/Eventuri Intake/TCKline Single Adjustable 500lbs Front 600lbs Rear/TCKline Camber Plates/Turner Adjustable Rear Control Arm/Turner Monoball RTABs/Turner Monoball FCABS/ Whiteline Front Sway / Brembo GT 6 piston Front 4 Piston Rear/OEM CSL Trunk/ CSL rep 1 piece lip
Jump to top Sandeep1212 is offline   Reply With Quote
Old Wed, Dec-04-2019, 12:06:35 AM   #9
lmtfi
lmtfi's Avatar
They are stone guards to keep stones from lodging between the pad and rotor. Punched mine out long ago. Prolly lying about somewhere.
Old Wed, Dec-04-2019, 12:51:34 AM   #10
sapote
No, these covers on the leading edge of the wheel arch and so it has nothing to do with brake rotor.
Discussing What are these covers for? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
