Old Tue, Dec-03-2019, 07:56:54 PM   #1
rcracer2471
Reputation: 0 rcracer2471 is on a distinguished road
Default How to Pass with Supersprint Headers?
Looking to purchase Supersprint V2 Headers from Turner before their Sale ends tonight. What measures have to be taken to pass inspection aside from the sniff test? Is a header tune necessary? Looking to pair up with my SS Race Exhaust. Any help would be great. thanks.
Jump to top rcracer2471 is offline   Reply With Quote
Old Tue, Dec-03-2019, 07:59:14 PM   #2
Whitehawk8
Whitehawk8's Avatar
Reputation: 0 Whitehawk8 is on a distinguished road
Default Re: How to Pass with Supersprint Headers?
This topic has been discussed many times. Any header tune really. Or you can use ECU worx for $25
I passed catless with no faults
2003 M3 StahlGrau Metallic | Beisan | JB Racing | Koni | CMP | TMS | OEM SSK
Jump to top Whitehawk8 is offline   Reply With Quote
Old Tue, Dec-03-2019, 08:04:41 PM   #3
There's 15 years of info on these boards. It's been asked so many times. Just search.
Old Tue, Dec-03-2019, 08:04:54 PM   #4
usdmej
What measures have to be taken to pass inspection aside from the sniff test? .
inspections differ from state to state and even county to county
where are you located?
Jump to top usdmej is offline   Reply With Quote
Old Tue, Dec-03-2019, 08:06:06 PM   #5
vapeatl
Reputation: 0 vapeatl is on a distinguished road
Buy a OBD USB cable and code out the post cat o2 sensors and heater circuits.
If you don't want to deal with coding it yourself, buy the cable and ECUworx will do the dirty work for you.
This obviously wont help with visual inspection, sniff test, or the fact that the emissions guy is going to smell your car from a mile away.
Jump to top vapeatl is offline   Reply With Quote
Old Tue, Dec-03-2019, 08:06:49 PM   #6
rcracer2471
Im located in MA
Old Tue, Dec-03-2019, 08:21:21 PM   #7
MA is one of the tougher states. You'll need to modify your tune so that the cat check passes even with the O2 sensors wrong, but you'll also need to make sure they read not-ready immediately after clearing (they sometimes check that if suspicious), and you'll also have to change things such that the CVN matches the stock tune (which basically means your checksum needs to be stock -- this can be brute forced).
Old Tue, Dec-03-2019, 08:23:31 PM   #8
Whitehawk8
Whitehawk8's Avatar
I donít know what kind of stations youíre going to but I have never, not once, came across a smog employee who gave a single damn if I was cheating or not
I mean the place literally smelled like catless fumes when we were done and not a peep from his mouth
Old Tue, Dec-03-2019, 08:26:36 PM   #9
The Lewtz
The Lewtz's Avatar
Reputation: 0 The Lewtz is on a distinguished road
They finally stopped doing them in SC.. b/c basically everyone knew "a guy" who would take $20, and sign the stuff for you doing nothing. Easy for the guy and easy for customer. I'm always surpised when i hear of other states still doing them, I mean I don't think we have them in 15? 20? yrs
*edit removed article was junk*
Yeh we have not had inspections since '95.
Jump to top The Lewtz is offline   Reply With Quote
Old Tue, Dec-03-2019, 08:30:50 PM   #10
usdmej
that's why inspections vary from state to state/ county to county
in california a smog shop can be heavily fined and lose it's license for looking the other way. i assume this is heavily enforced due to the lack of stations that are willing to do so. at star stations (stations designated to do a more thorough inspection for cars known to be modded) the techs are very well educated on what's stock and not stock. i've had a tech point out that my euro headers and euro cats were illegal (even though OE) because the cats were not where they were supposed to be for a US vehicle
Discussing How to Pass with Supersprint Headers? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
