Old Wed, May-29-2019, 01:26:39 AM   #1
Arith2
Arith2's Avatar
Reputation: 0 Arith2 is on a distinguished road
Default The game we play with these engines
It's a little embarrassing to have 71k mile S54 blow up on a dyno but it happened. However, I'm not surprised nor am I really upset because BMW fudged up a critical component that is easily destroyed. I haven't had much time because I'm moving to Orlando this week so the true reason it blew isn't fully determined. My speculation is the head gasket blew out and I'm pretty sure I spun a bearing.
Going back and looking at the video we took of the run, you could hear knocking after the third run. We totally caught it on video which I would love to post when I get the video. My exhaust was so loud that there was no way anyone would've heard knocking in person. Headers + Gruppe M muffler is LOUD inside a building, even at idle. It had that amazing racecar sound at WOT. It was a glorious way to go out.
Once I move I'll take it apart and hope my HOA doesn't fine me for doing so. This is a great excuse to throw in forged internals, a better head gasket, WPC bearings(I should've did this immediately), do a 6MT swap, and get some Supersprints.
I'm open to suggestions on what internals and gasket to use as this will be my first engine rebuild. I know everyone here seems to hate VAC but I can literally drive there to pick up parts. Price matters but I'm not going to put garbage in my car. I figured $5000 is a good budget for an upgraded engine build. To me, making it robust enough to handle FI isn't a waste even though it will stay NA. I'm also tracking BMW says the S54 is a no machine block. What can I get away with if it is slightly warped realistically?
This is the Driver's side. That rod doesn't move. At least it's still connected.
The top half of the rod which I found underneath the rear side of the plenum on my starter.
My piston is just gone. It just didn't survive.
Here's my head:
The pin out of the piston:
The passenger side where the top of the rod cam out:
What I've removed so far:
'06 Alpine White III - Cinnamon Interior
Buildjournal Tune | CSL Trans Software | Megan Racing Headers | Turner Power Pulleys | GruppeM Ti muffler | K&N Filter | ECS Silicone Intake Boot | SMG(Conversion coming one day) | Stainless Steel Vanos line | Dinan Strut Reinforcement bars F&R | OEM Sec 1 and 2 Exhaust | OEM Intake | Pioneer Radio | CSL Trunk | Headliner that isn't Saggy | Poorly Wrapped Steering Wheel by Previous Owner | OEM Suspension | Aftermarket Driver Holes in engine block for better airflow(Flintstone powered)
Jump to top Arith2 is offline   Reply With Quote
Old Wed, May-29-2019, 02:07:26 AM   #2
Nambo
Reputation: 0 Nambo is on a distinguished road
Default Re: The game we play with these engines
Dang sorry for your engine troubles. I know the feeling but you seem incredibly optimistic about it. Good for you! No recommendations here. Still learning and kicking wounds as we’ll.
Jump to top Nambo is offline   Reply With Quote
Old Wed, May-29-2019, 02:14:12 AM   #3
11b4
11b4's Avatar
71k mile s54. Assuming it's a 2003+ model. Which should of been recalled or covered by bmw.
Old Wed, May-29-2019, 02:19:30 AM   #4
eacmen
This s54 build had me drooling when it got listed on BAT: https://bringatrailer.com/listing/bm...raine-package/
Personally I'd go to an s54 engine builder and get the whole long block built to spec instead of doing it myself. That's a level of skill I just don't have. Lang Racing comes to mind but I have no direct experience with them.
Probably blasphemy on this forum but have you considered LS swap? There was a for sale listing for all the parts you'd need.
[RIP] 2001 E46 M3, Tilton Triple Disc Clutch, JRZ RS2 (750/650), ST-40 332mm front BBK, BW TA16 Square 18x9.5, RE-71R 265/35R19, Redish Motorsport Plates, Mason X-Brace, Mason Front Strut Bar, RaceCapture Pro MK3 w/custom Raspberry Pi Dash.
Jump to top eacmen is offline   Reply With Quote
Old Wed, May-29-2019, 02:28:56 AM   #5
jickel180
Fair Enough
jickel180's Avatar
Reputation: 0 jickel180 is on a distinguished road
Highly unlikely it was a head gasket. Highly likely it was just your rod bearings.
Personally I would find another long block, take care of the VANOS, rod bearings, chain guides, etc. and go from there. Adding higher compression pistons, machine work, and possibly another crank adds too many variables for catastrophe in a sub 400 whp build.
Jump to top jickel180 is offline   Reply With Quote
Old Wed, May-29-2019, 02:41:26 AM   #6
.'s Avatar
Reputation: 0 . is on a distinguished road
Sorry to hear that man! I just went through a full rebuild (for different reasons) and I’m in the Orlando area so if you need any help when you get down here let me know.
2001 E46 M3 - Slicktop Manual Coupe - Alpine White on Imola Red
Engine: Karbonius CSL airbox, Lang Racing stage 2.5 head, Schrick 288/280 cams & followers, Lang Racing rod journal widening kit w/ CP 12:1 87.5mm pistons & Carrillo rods, Kassel CSL DME & MAP conversion, 36lb injectors, Hassan tuned, APE Flex fuel kit, TMS Power Pulleys, SS V1 stepped headers & catless section 1, SS 2.5” twin-piped resonated section 2, SGT scza section 3.
Drivetrain: DKM Stage 2 Clutch, E60 Shifter, RE trans mounts, Motorsport 4.10 R&P, Revshift 80A diff bushings.
Suspension/Brakes: Ohlins 3DM “track day” kit, RE strut bar, AKG RSM's, UUC front sway bar, BW camber arms, TMS monoball RTABs, ZCP rotors, BW solid caliper guide bushings, PFC 08's, Motorsport Hardware stud kit.
Interior: Cobra Nogaro seats, alcantara headliner, BMW Performance pedals, OE alcantara boots, mason clutch pedal, Xtrons 9" headunit w/ carplay
IG: Zach_e46M
Jump to top . is online now   Reply With Quote
Old Wed, May-29-2019, 02:50:49 AM   #7
fattycharged
can't even
fattycharged's Avatar
Zimbabwe
Buy good used block and do all maintenance then reinstall.
Sell old good parts
Sent from my iPad using Tapatalk Pro
Topo Chico
Old Wed, May-29-2019, 02:58:06 AM   #8
Arith2
Arith2's Avatar
I've been looking for blocks but I would rather reuse my block rather than waste money if mine is fine. I've haven't verified I can't reuse mine yet so it's on the table. The previous owner mentioned doing the head gasket so that's why I'm thinking the bearing and head gasket combo. 20 bucks says he reused the head bolts. It has had the Beisan treatment twice and I even threw some Rem polished sprockets in there which are quieter. Exhaust hub is a Turbo hub which seemed very solid. I'm not trying to add compression and will avoid every bit of machine work I can as this is a no machine work block. If the crank isn't completely marred I'll get it polished as a preventative measure.
Absolutely! I'm moving Saturday and the car is sitting at the new house in the garage. This is my first rebuild so I won't be attempting this alone. I'm so ready to jump into this but I can't let my pride and eagerness cloud my judgement.
It's a 2006 so no recall. My 2002 had the recall done and had about the same mileage on the bearings when it got totaled.
Old Wed, May-29-2019, 03:05:42 AM   #9
Arith2
Arith2's Avatar
I'm looking to do a rebuild for the experience more than anything. I am buying another daily driver and this will retire to my weekend car once it works. If I wasn't, screw this engine, I'd sell everything but the rod bearings. It does have 71k miles which means something... I guess.
Old Wed, May-29-2019, 03:09:52 AM   #10
GrendelsbaneM3
GrendelsbaneM3's Avatar
Reputation: 0 GrendelsbaneM3 is on a distinguished road
I am in the process of rebuilding my engine for my car. Cylinder 2 detonated on me. I think the head gasket bolts stretched and it went. When engine was blown apart, rod bearings (WPC were good), but cylinder 2 looked scored and the piston head was pitted. I bought a solid used engine and had my mechanic change out the rod bearings, put in a MLS head gasket, and swap out the bolts for ARP. I swapped out the stock pistons and rods for forged Carillo pistons and rods. Bored out the cylinder to 87.5mm. I am using VAC rod bearings and center bearings. However, I am using Lang Racing fto get a stage 2 cylinder head work.
2004 Silver M3 / SMG / TC Kline DA Coilovers / Eibach front and rear sway bars / Proflex bushings / Predator Orion V2 Multi-Color LED Angel Eyes / ALPS Jammers / Clear Bumper Reflectors / Zionsville Competition Cooling Kit with Offset Fan / AKG Motor mounts / Rogue Engineering Transmission Mount / AKG differential bushings / Euro mirrors / B&B Exhaust / CSL SMG tune /DME CSL tune / ESS 575 Supercharger / Stillen AP Racing BBK / J-Fiber Carbon Fiber Driveshaft
Jump to top GrendelsbaneM3 is offline   Reply With Quote
Discussing The game we play with these engines in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
