Old Mon, Jul-09-2018, 02:36:06 PM   #21
EYEHAVEYOU
Simon
EYEHAVEYOU's Avatar
Default Re: CF CSL Style Intake with OEM MAF (Ebay (BS-Parts))
Tuners can put all the US OBD2 emissions stuff on the CSL flash. Doing so makes it every bit as plug and play with state emissions computers as the stock car.
This is the first I'm hearing of this, something Kassel does? Everything I've read to-date said I'd have to swap DMEs in order to pass NY emissions if I went the CSL airbox route.
Old Mon, Jul-09-2018, 03:41:31 PM   #22
tasi
Reputation: 0 tasi is on a distinguished road
That's what I've read as well, so far.
SCZA | Euro Headers | SG High Flow Cats Sec 1 | Ohlins R&T w Vorshlag | BPM Tune | RTD Shifter | Radium Oil Catch | Mishimoto Fan+Radiator | VibraTechnics Motor Mounts | Turner Solid Subframe Bushings | Turner Rear Camber Arms | Rouge Bushings, Tranny Mount and Pulley's | Mason Clutch Pedal | PFC-08 w Stoptech ST-40 BBK | Bimmerworld Vanos Line | WPC Bearings | Besian Vanos | Reddish Subframe Plates | CF CSL Trunk | Apex Arc-8 RE-71R
IG: @tariqali
Jump to top tasi is offline   Reply With Quote
Old Mon, Jul-09-2018, 03:54:19 PM   #23
Originally Posted by tasi View Post
Thanks Obioban, that would be great, could you point me to a couple tuners that are able to do that?
Never used Kassel, so can't speak to that.
Both Evolve back in the day (don't know if they can anymore), and MCCHIP-DKR more recently were able to do it for me with no issue.
With the MCCHIP-DKR I forgot to ask for it originally and went to get it inspected... failed. Asked for it, he sent me a new flash, went back to the same shop and it passed... so I'm very confident they did exactly what they said they were doing.
Old Mon, Jul-09-2018, 05:33:28 PM   #24
tasi
This is pretty awesome, so did you just get their stage 1 tune and have them code the OBD emission settings? Or did you work with them for a completely custom tune?
Also did they do the CSL software, or did you already have that?
Thanks for sharing, very helpful.
IG: @tariqali
Old Mon, Jul-09-2018, 05:39:16 PM   #25
I have a custom tune-- but I'm sure the emissions stuff could be added to either.
They did the CSL conversion for me, as well.
Old Mon, Jul-09-2018, 06:37:51 PM   #26
EYEHAVEYOU
Simon
EYEHAVEYOU's Avatar
Thanks for sharing this, passing emissions was my major hangup in going CSL airbox route (the other concern being no OEM-like routing method for hoses/pipes without CSL bumper, but I can live with that). Going to pick up a Karbonius soon.
Old Mon, Jul-09-2018, 06:50:01 PM   #27
HassanEido
HassanEido's Avatar
Lebanon
Sorry for the late reply, but no no maf in my setup. Not possible to have this much of a large opening and have a maf accurately measuring the air that's going thru it. It's why bmw went with the map sensor/alpha N hybrid.
Im all for running a map sensor if ur ecu is post 2003. For the non hp dme guys, a custom dyno alpha N tune basically runs as good as stock. No hesitation no bucking. Smooth as silk with consistant power
PM for performance tune requests
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Old Thu, Jul-26-2018, 07:50:56 AM   #28
tasi
Just put in a new strut brace since the OEM wouldn't for anymore
IG: @tariqali
Old Sat, Jul-28-2018, 06:20:42 AM   #29
tasi
Replaced the small Specter filter with a bigger K&N, should be able to breathe better now.
IG: @tariqali
Old Wed, Oct-24-2018, 04:23:21 PM   #30
tasi
Another annoying issue I found with this setup.
Just did an oil change for the first time with the intake, and the intake extends just enough over the oil filter housing to block the oil filter. At the moment the only option was to remove the intake, or slightly bend the filter to force it in/out.
Ugh! what a PIA, so many regrets with this setup
At least it feels and sounds good, gotta get it on a dyno to see how it actually performs.
Just a friendly update, obviously still don't recommend this setup at all.
IG: @tariqali
carbon, csl, e46m3, intake
Discussing CF CSL Style Intake with OEM MAF (Ebay (BS-Parts)) in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
